6thgen issues
Old Dec 18, 2007 | 12:01 PM
white99CF's Avatar
Default 6thgen issues
can someone assist me with my struggle to drive my car again.
99 accord dx:i/e, plugs,plug wires,msd cap & rotor walbro pump.
the car starts fine runs ok then once i accel and get to 2500rpms the car's whole engine sound changes as if the car is struggling for fuel or somethin and once i come to a stop 8 outa 10 times it ll die!
NO CEL either
PLZ any help is highly apprec.
99k miles
Modified by white99CF at 3:45 PM 12/18/2007
Old Dec 18, 2007 | 12:32 PM
jweller's Avatar
Default Re: 6thgen issues (white99CF)
check your ignition coil and the ICM
Old Dec 18, 2007 | 02:43 PM
white99CF's Avatar
Default Re: 6thgen issues (jweller)
ok could u explain y i would need to check my ignitor coil.? and wut is a ICM???
Old Dec 20, 2007 | 11:41 AM
jweller's Avatar
breaking up at high RPMs is foten an ignition problem. if you've replaced the cap rotor and wires then that only leaves two things: the coil and the ICM ignition control module. it's a small electronics module inside the distributor
Old Dec 20, 2007 | 06:06 PM
Ronin1's Avatar
This sounds like a real probability. I had a car with a bad coil that would cut out like someone had flipped a switch when it hit a particular RPM. I borrowed a coil to test it and the problem disappeared. A new coil and it was good to go.
I am not sure if there is a good test in the factory manual for the coil. Do you know the resistance that the coil should test at?
Anyway, I agree that this is one of the "usual suspects" to check out.
Old Dec 22, 2007 | 09:03 AM
white99CF's Avatar
Default Re: 6thgen issues (Ronin1)
ok now just to add when i checked my cap<msd extreme cap and rotor> 3 of the four towers almost look like they taken some serious wear considerin the one left clean and brass had little to no wear it seems, would an external coil help?!
mightyjoecivic
11
Jul 13, 2022 08:04 PM
chrisdavis6
Feb 4, 2008 05:19 AM
bennyDA
Nov 9, 2006 04:28 AM
loki2323
Sep 3, 2005 11:44 AM
