Honda S2000 Honda S2000
Oil Pan / What should I buy ?
Old Dec 18, 2007 | 11:43 AM
Nagata-San74's Avatar
Default Oil Pan / What should I buy ?
hey
I tried the search, but couldn't find infos.
What oil pan should I buy ?
I found Mugen, J's, Spoon... maybe even buy the hardware to install in my pan.
Thanks for infos !
Old Dec 18, 2007 | 11:45 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Oil Pan / What should I buy ? (Nagata-San74)
and whats wrong with your OEM pan?
Old Dec 19, 2007 | 02:17 AM
Default Re: Oil Pan / What should I buy ? (S@nt0s)
Like almost every F20C oilpan, it doesn't like G's.
WHen you touge fast ro drift, you might have big big problems, like some friends already have.
First sign is the 22 CEL, Vtec pressure, meaning your oil moves too high in the pan.
THat's why it's HIGHLY recommended to get an aftermarket one.
Old Dec 19, 2007 | 03:57 PM
iam7head's Avatar
even on a front midship rear sump motor?
Old Dec 19, 2007 | 04:13 PM
envee's Avatar
I say go dry sump. If you are serious into drifting or road racing you need too anyway.
Old Dec 19, 2007 | 08:45 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nagata-San74 &raquo;</TD></TR><TR><TD CLASS="quote">Like almost every F20C oilpan, it doesn't like G's.
THat's why it's HIGHLY recommended to get an aftermarket one.</TD></TR></TABLE>
thats funny because i have YET to hear of such a issue
Old Dec 23, 2007 | 09:04 AM
Mr. Projekt's Avatar
* B A N N E D *
Words like "might", "some friends" and "highly recommended" are killing your argument.
Have you ever gone through oil starvation on this car? If so, you're probably low on oil.
If you wanna bench race/bench engineer some ****, then here goes. "iam7head" is correct about it being a rear sump, which means the car would experience oil starvation during hard braking, or trailbraking into a corner (yeah right). To create that amount of G's, you'd have to have a LOT of tires up front, or else you're just overloading the fronts and understeering those G's into tire smoke.
Not that I don't like the idea of a baffled pan. We do run them on our cars.
And X2 on the dry-sump if you're going to road race seriously.
Old Dec 26, 2007 | 08:21 PM
bky's Avatar
bky
I haven't heard of any oil starvation problems with the S2000 under hard cornering, but I don't know enough drift S2000s to be knowledgeable about those issues. However, according to GPS data we collected during a drift event, the g-forces experienced by a well driven S14 were less than or equal to the g-forces in a grip car. They g-readings were usually well inside the friction circle of a grip car.
The interesting thing was the direction of the g-force vector relative to the car. It usually points to towards the center of the turn radius like in a normal grip car, but instead of being perpendicular to the grip vehicle, it still points to the turn center despite the drift angle. Interesting stuff, but I digress: the point is that I didn't notice the g-forces in a drift to be any higher than in a grip car (usually lower), though the duration tends to be longer.
Old Dec 27, 2007 | 01:20 AM
Default Re: Oil Pan / What should I buy ? (Mr. Projekt)
Sorry, 3 engine smoking on MagnyCours on right curbes and braking, 2 broke in drift...
In Europe it's a well know mod-to-do on the F20C !
NW94RS
Aug 5, 2004 09:50 AM
djickabod
16
Apr 26, 2004 02:59 PM
Speedworks801
Sep 5, 2003 01:21 PM
gsrcivict
May 20, 2003 10:06 AM
velocitysir
Dec 1, 2002 04:51 PM
