Anyone having problems with the Moroso Pans?
Old Sep 4, 2003 | 11:07 PM
Speedworks801's Avatar
Default Anyone having problems with the Moroso Pans?
I think I am having problems with the Moroso Pan oil return location. It routes the oil back in below the oil level in the pan. I think this may be causing some back pressure on the oil and possibly forcing it past the seals and into the intake tract. Does anyone have a similar problem?
Are you guys using anything to control oil pressure to the turbo as well?
Thanks in advance
Old Sep 4, 2003 | 11:36 PM
Full-Race Geoff's Avatar
Default Re: Anyone having problems with the Moroso Pans? (Speedworks801)
i think they are too low. same with z10, but that is probably becuase i think moroso makes the z10 pan.
Old Sep 4, 2003 | 11:38 PM
BrokenVtec's Avatar
Default Re: Anyone having problems with the Moroso Pans? (FFgeoff)
i think the pan is also the cause for my car smoking so much.... for some reason it never smokes while i am facing up-hill..... it has to be the pan
Old Sep 5, 2003 | 12:36 AM
saso
Guest
Posts: n/a
Default Re: Anyone having problems with the Moroso Pans? (508@18psi)
Its the pan do a search, this has been discussed before.
Old Sep 5, 2003 | 12:39 AM
Bnjmn's Avatar
Default Re: Anyone having problems with the Moroso Pans? (saso)
So the fix is to weld in a higher return location on the Moroso pan?
Is the pan even worth it otherwise? I read guys in the road racing forum saying that it wasn't too good at keeping the pickup in oil.
Any have any experience with the Spoon/Mugen pan? I'm going to be road racing so I need something baffled that actually works.
Old Sep 5, 2003 | 05:07 AM
Blown90hatcH's Avatar
https://honda-tech.com/zerothread?id=577686
Old Sep 5, 2003 | 08:33 AM
Bnjmn's Avatar
Default Re: Anyone having problems with the Moroso Pans? (Blown90hatcH)
So it is still working out- just add about 4 quarts?
Old Sep 5, 2003 | 01:21 PM
Default Re: Anyone having problems with the Moroso Pans? (Bnjmn)
Yeah man. It is working great now. I just keep the level at 4 quarts and have no problems with it.
Jason
STN_Pat
Nov 29, 2012 04:05 AM
joshualeet
13
Oct 2, 2008 08:17 PM
