Old Mar 31, 2015, 04:28 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Overview
Print Wikipost
FAQ: Acura Recommended Maintenance Schedule
Old Jun 27, 2002 | 04:07 PM
uNF$@#!'s Avatar
Default FAQ: Acura Recommended Maintenance Schedule
<u>7.5k-22.5k-37.5k-52.5k-67.5k-82.5k mile service</U>
Change Engine Oil & Filter
Check Clutch Adjustment & Fluid Level
Inspect Front Brake Pads, Rotors and Calipers
Inspect Fluid LEvels
Adjust Parking Brake
Inspect Exhaust System
Inspect Tire Wear & Set Tire Pressure
Check hoses, belts & coolant level
check wiper blades & windshield washer fluid level
inspect power steering fluid level
inspect transmission fluid level
inspect front suspension & steering operation
rotate tires
<u>15k/45k/75k mile service</U>
Change Tranny Fluid
Replace Fuel Filter
Replace Air Filter
Inspect Front & rear Pads, Rotor & calipers
Inspect all fluid levels
adjust parking brake
inspect clutch operation, adjust freeplay and check fluid level condition
adjust all belts
inspect suspension mounting bolts for tightness
inspect exhaust system
inspect tire wear and set tire pressure
check hoses belts and coolant level
inspect battery and clean terminals
adjust alternator belt
inspect valve clearance
check wiper blades and winshield washer fluid
lube door, hood latches and hinges
rotate tire and balance
inspect and clean spark plugs
inspect cap and rotor
road test
<u>30k/60k/90k mile service</U>
Change Tranny Fluid
Replace Fuel Filter
Replace Air Filter
Replace Spark Plugs
Replace Distributor cap, rotor and inspect wires
set ignition timing and adjust cambelt
Inspect crankcase emissions
Inspect front & rear pads, rotors and calipers
Replace brake fluid, check hoses & lines
replace clutch fluid, clutch operation, adjust freeplay
adjust all belts & inspect power steering fluid
replace engine coolant & check hoses belts
check wiper blades and windshield washer fluid
[Modified by Soup ****, 6:20 PM 7/6/2002]
Old Jun 27, 2002 | 04:32 PM
uNF$@#!'s Avatar
Default Re: FAQ: Acura Recommended Maintenance Schedule (zyg)
This is all in the owners manual, isn't it.
well, uhm, i wrote this up for the people without opposable thumbs to open books
Old Jun 27, 2002 | 04:58 PM
uNF$@#!'s Avatar
Cool.
Now how about the severe use schedule.
simple, take all mileage and divide by 3
Old Jun 27, 2002 | 09:53 PM
yoshi234's Avatar
I shoot brides
Default Re: FAQ: Acura Recommended Maintenance Schedule (00-0187)
daym, that's a lot of typing
I'll FAQ this when I get to work tomolo
yshi - who just got back from The Block w/ 234 in one piece
Old Jun 27, 2002 | 09:56 PM
Chris's Avatar
Thanks!
-Chris, who has 30K miles... real hard ones.
Old Jul 6, 2002 | 02:21 PM
uNF$@#!'s Avatar
Default Re: FAQ: Acura Recommended Maintenance Schedule (Chris)
no problem
Old Jul 6, 2002 | 02:56 PM
Jsracingintegra
Guest
Posts: n/a
Default Re: FAQ: Acura Recommended Maintenance Schedule (Soup ****)
Thank you
Old Jul 6, 2002 | 05:24 PM
2kbill's Avatar
Default Re: FAQ: Acura Recommended Maintenance Schedule (Jsracingintegra)
Thanks I'm printing that and stapling it up in my garage.
Old Jul 6, 2002 | 05:31 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: FAQ: Acura Recommended Maintenance Schedule (2kbill)
way to help out the lazy asses
Old Jul 6, 2002 | 06:23 PM
ZygSpeed's Avatar
Default Re: FAQ: Acura Recommended Maintenance Schedule (RealTypeR)
LOL!
I don't see the clean and lube of the antenna.
Old Jul 6, 2002 | 06:56 PM
uNF$@#!'s Avatar
Default Re: FAQ: Acura Recommended Maintenance Schedule (Zygspeed)
LOL!
this is the acura maintenence papers, straight from acura dealers...
Old Jul 6, 2002 | 07:04 PM
ZygSpeed's Avatar
Page 129 of my 97 Owner's Manual lists "Clean antenna mast" under the severe condition maintenance schedule @ 15 K mile increments.
Other than that, you've pretty muche covered everything else.
P.S. -- Oddly enough it also says that Canadian owners should follow the severe maint. schedule.
Old Jul 6, 2002 | 08:20 PM
neo1z's Avatar
yea man, i seriously appriciate it
Old Jul 7, 2002 | 05:30 AM
Slick GS-R's Avatar
Default Re: FAQ: Acura Recommended Maintenance Schedule (George Knighton)
thanks man, i appreciate your work
Old Mar 1, 2003 | 06:27 PM
stormywaters's Avatar
Change Tranny Fluid
uh... i took my itr to a local independent repair shop with a good reputation for it's 15k service, and they told me i don't need to change the tranny fluid till 30k. i brought up changing the tranny fluid, but they said i didn't need to worry about it. am i in danger of voiding a warrenty? do i need to take the car back in, or is it a relatively simple proceedure?
Old Mar 1, 2003 | 06:30 PM
uNF$@#!'s Avatar
Default Re: FAQ: Acura Recommended Maintenance Schedule (stormywaters)
I'd never thought i'd see this thread brought up again.
if you have the rear spare jack in the car, you can change the tranny fluid.
Old Mar 1, 2003 | 06:33 PM
yeah... i like bringing things back from the dead.
well... i do have the rear spare jack, so i guess i can do it myself. what size tool do i need? any tricks i need to know? how much honda tranny fluid do i need to pick up?
[Modified by stormywaters, 3:36 AM 3/2/2003]
Old Mar 1, 2003 | 06:55 PM
uNF$@#!'s Avatar
1 liter will do.
do a search, lots of times this has been put up.
basically theres a drain/fill plug. i think they are 19/17mm respectively, but with my forgetful mind, better look it up.
torque wrench, and a tube/funnel to feed the fluid in. thats it.
if you dont feel confident doing this, just goto the dealer and have them do it.
its a no brainer, but some people arent cut out for even this sort of work. good luck. i believe theres a page on c-speedracing.com that covers this.
[Modified by Soup ****, 10:56 PM 3/1/2003]
edit: (one year later) : i cant believe i said 1 liter....prolly closer to 2-2.2 quarts
Modified by Soup **** at 12:50 AM 1/26/2004
Modified by Soup **** at 12:51 AM 1/26/2004
Old Mar 1, 2003 | 07:33 PM
Chris N's Avatar
wow, OLD thread.
Tranny fluid change is so easy, even I can do it.
Check out the 'how-to' section on c-speedracing.com like Master Soup said.
BTW - is/are the c-speedracing person/persons on h-t??
Old Mar 1, 2003 | 08:10 PM
uNF$@#!'s Avatar
Default Re: FAQ: Acura Recommended Maintenance Schedule (Chris N)
i dont know, but one of their supposid project cars is on egay for sale!
nukem384
Mar 16, 2010 07:20 AM
io_burn
Aug 20, 2003 02:29 AM
SonicGSR
Oct 9, 2002 08:16 PM
SonicGSR
Oct 9, 2002 07:28 PM
EminemGSR
Sep 18, 2002 05:34 PM
