apex n1 ? over the axle or under
the 90mm apex n1 for the type R does it go over or under the axle , how are the clearence issues an will anything have to be modified for it to fit correctly , an does anybody have some pics of one on a py itr
i just wanna no what im in for when i get mine
thanks alot
eric
thanks alot
eric
Sup, I believe it goes over the axle. And if your ride is slammed then you will scrape the can. I dont think there is any modifications and the exhaust is the same as for the LS model integra. I dont have pics on a yellow but I have on black. I can send them to you if you want?
i put mine below axle with custom piping and straight as possible. i can also work with it better; like putting it on an angle. i also had to modify the bumper a little, cuz it rubbed. it still rubs a little. my can scrapes if i back out of a driveway too fast. http://www.imagestation.com/members/LOWCO-R
[Modified by LOWCO R, 11:23 PM 6/28/2002]
thanks alot
eric
thanks alot
eric
The Apex N1 goes under the axle. On the NA setup and the turbo set up as well.
Question: How's that 90mm piping? That's over 3.5 inches diameter...
The piping for n/a N1 for all integras is over the axle. I'm not sure about the turbo, i'm pretty sure its the same with turbo. If you didn't buy the cat-back, i guess you could have the choice of going over or under with the universal canister.
sorry i dont mean to keep callin it under the "axel" just thats what its called somtime like you get a axle back or what not , anyway which version if any goes under the axel , an when i said 90mm i meant the tip size i thought that was how they were seperated i might be wrong but anyway what sizes are there tip size an piping size on each system , and if anybody has some pics of one on a py itr that be awesome
thanks alot
eric
thanks alot
eric
hey eric, if u wanna see my n1 "below axle" send me an e-mail..... i got it in mpeg form.
ml00z@rogers.com
ml00z@rogers.com
SloCivicHMM
Aug 12, 2003 09:31 AM
EFing8
Dec 12, 2002 05:32 PM
