Auto->Manual Conversion. Can I use 5spd pedal assembly temporarily with auto tranny?
I am converting my 96 ex from auto to manual and was wondering if anybody knows if I could possibly install the new pedals on my current (auto) tranny setup and just let the clutch pedal hang free until I have time to convert everything else.
Basically I'm wondering what parts of this swap I can break down and get done while keeping the car driveable >_<
Here's my project thread btw:
https://honda-tech.com/zerothread/2177326
thanks in advance.
thanks in advance.
you prolly could...i wouldnt reccomend it, it would just be a pain in the ***
im gettng an auto to manual swap also, its actually almost done...
well if it helps you out, heres my 2 cents, just dont jump the gun
well I'm not really jumping the gun, I have taken my time gathering everything for the most part and have read up a ton on the subject.
be sure to check out the thread I linked in the OP since I have another problem there which is towards the bottom of the post.
Yeah, I will probably set aside a day to do the pedals then
so did you guys convert EK's also?
any other tips?
thanks!
any other tips?
thanks!
I'm doing the exact same thing i'm putting a b16 in mine and it's getting complicated lol
I've been drivng around for awhile now with a clutch pedal it'ss just fall to the floor anyways because there is no pressure in your lines
complicated why? because i have a cable tranny and a obd0 b16a i have the conversion mounts and kit for the hydro to cable conversion just converting the b16 is a pain
oh and you don't have to pull the entire pedal assembly to change the pedals
The brake arm itself if you remove the bolt the it pivots on which i believe was a 12mm you can play with it abit and take it out and put the new one in the only hard part is the spring which i used needle nose pliers
the clutch pedal assembly the bracket pedal etc is seperate and is only 3 or 4 bolts and that is real easy to put in
oh and remove your driverside seat so you can lay on the floor on your back it'll make things sooo much easier any question let me know it's not hard at all
the cotter pins a bit of a pain in the *** but i just broke mine and get new ones if you twist them they break real easy
yeah I don't know where I would be without Luserkids guide.
to BWek:
wow man, that makes me feel a tiny bit better at least...
I'm just trying to take things slowly, but at the same time I can't wait till I'm driving this baby as a 5spd.
I emailed ACT about my pressure plate question (not sure if the pp I ended up with is the right one), but I'm on the verge of buying an exedy kit.
read my project thread for more.
edit: I meant to say your job is way bigger than mine BWek.
also, hmm I never thought about just breaking/replacing the cotter pin
to BWek:
Yes you can, I did it that way for about a month until I gathered all my parts. All my friends laughed at it tho, Swap over the brake arm from the manual set of pedals to prevent the clearance issue.
ya everyone trys to save the 12 cent cotter pin lol
just swap the brake arm and you can use your original throttle cable and you don't have to drop you steering column to do it and do you do not need to take your interior apart just take a flash light in there it took me about 45 mins to do the swap over in my car
if you were closer I would say come over and let s do it but you aren't
make sure you take your seat out it makes it soo much easier!!!
Oversoulx2
Oct 16, 2007 05:20 PM
Sarpedon
Aug 18, 2004 02:45 PM
c1civic
10
Apr 6, 2004 05:06 PM
