MFactory Close Ratio Gears Installation
Old Dec 17, 2007 | 03:53 PM
jdm_teg_gs's Avatar
Default MFactory Close Ratio Gears Installation
Hey Guys,
How long would it take to install the close ratio gear set on my 2000 ITR transmission from a shop? 5 hours?
Thanks
Old Dec 17, 2007 | 03:58 PM
JjuuN R's Avatar
??? It'll be different for everyone... remove tranny, open case, replace gears, close case, install tranny.
Old Dec 17, 2007 | 04:06 PM
AssPenny's Avatar
Default Re: (JjuuN R)
Air tools and and lift it can be done in probably 3 hours or less... doing it on the ground with wrenches you are looking at about twice as long. Its really straight forward and as long as you have all the tools (puller, tube to press gears on, etc..) its pretty easy.
Craig - Who thinks the record is >2hrs for a final drive install.
Old Dec 17, 2007 | 08:33 PM
Aquafina's Avatar
Default Re: (AssPenny)
A shop will probably charge by the book (shops use a book that lists time for different jobs).
Takes me about 2 hours from taking the trans out to getting it back in just for a gear swap.
Old Dec 18, 2007 | 08:32 PM
jdm_teg_gs's Avatar
Default Re: (Aquafina)
Thanks Guys. Looks like it might be an expensive install from a shop.
Old Dec 18, 2007 | 11:01 PM
Aquafina's Avatar
Default Re: (jdm_teg_gs)
You can do it yourself...
Old Dec 19, 2007 | 03:59 AM
jdm_teg_gs's Avatar
Thanks for the confidence man, but I wouldn't trust myself to do that. I'm gonna try and see if a buddy at the dealership will do it for me and just pay him. Too bad you weren't in canada Aquafina, then you could make some good cash installing them for me. :-)
Old Dec 19, 2007 | 04:28 AM
Aquafina's Avatar
Pay me for gas round trip and I'll do it.
Old Dec 19, 2007 | 06:22 AM
citrus3000psi's Avatar
Its really not has hard as it sounds. If you can drop the tranny. Then you can tear apart the tranny period.
I had a harder time getting the shift linkage apart more then anything. Tearing down the transmission was easy. Except for that one bearing. Damn was it a pain to get off. (I didn't use any bearing pullers when i did mine)
Old Dec 19, 2007 | 07:34 AM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_teg_gs &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the confidence man, but I wouldn't trust myself to do that. I'm gonna try and see if a buddy at the dealership will do it for me and just pay him. Too bad you weren't in canada Aquafina, then you could make some good cash installing them for me. :-)</TD></TR></TABLE>
Get in touch with Rich at southside Acura or Jack at Honda or any number of those guys who are still in the game. Wai is very good too.
Though I'm guessing this is the crew whom you might be referring to.
Old Dec 19, 2007 | 02:51 PM
jdm_teg_gs's Avatar
Default Re: (RagingAngel)
Aquafina: That's a far drive from Tennesse... :-) But if your up for it....
RacingAngel: Thanks for the tip, I'll try and stop by Acura and Honda this weekend and talk to them. My buddy works at Westside Mitsu and probably knows these guys.
Old Dec 19, 2007 | 02:53 PM
jdm_teg_gs's Avatar
I've got the JDM Final drive and Prolite flywheel allready, so with the MFactory gears, my DC2R will pull pretty hard. Mu buddy has the ATS 3-4-5 Cross gears and it is amazing on his Type R.
Old Dec 21, 2007 | 01:15 AM
Aquafina's Avatar
I can do the install after New Years if you want me to. I'd just ask that you have the trans pulled from the car and a table vice available. Vice isn't absolutely needed, but it makes removing/installing the countershaft nut easier if you don't have a nice air impact.
Old Dec 21, 2007 | 02:03 AM
an2ny888's Avatar
don't forget the dremel to grind the tranny case
Old Dec 21, 2007 | 02:29 AM
Aquafina's Avatar
Default Re: (an2ny888)
I never go on a roadtrip without my dremel.
Not needed for the gear set install in a Z6 though . Y8 it is needed.
Old Dec 21, 2007 | 05:43 AM
I never had to grind anything on my case.
Old Dec 21, 2007 | 07:25 AM
Cdn01ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_teg_gs &raquo;</TD></TR><TR><TD CLASS="quote">I've got the JDM Final drive and Prolite flywheel allready, so with the MFactory gears, my DC2R will pull pretty hard. Mu buddy has the ATS 3-4-5 Cross gears and it is amazing on his Type R.</TD></TR></TABLE>
I had no idea you bought an R. Why didn't you post anything on abtegs or 780?
Old Dec 21, 2007 | 01:15 PM
jdm_teg_gs's Avatar
Default Re: (Cdn01ITR)
What part of edmonton are u at? I allready posted on 780 and beyond.
My Buddy says Wai will do it for $300 including taking tranny off. Does $300 CDN sounds good for a local guy?
Old Dec 21, 2007 | 04:23 PM
an2ny888's Avatar
Default Re: (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">I never had to grind anything on my case.</TD></TR></TABLE>
it depends on what gearset he got, if he has the 1.384 4th then he will have to grind the tranny case
mcmmotorsports
10
Dec 24, 2013 08:48 AM
MooreBoost
Mar 19, 2003 04:05 PM
Neptune
Dec 25, 2002 10:52 PM
type r 01-1063
Jul 18, 2002 01:32 PM
Rhetoric
Nov 1, 2001 02:02 PM
