Timing Belt Question???
Old Dec 17, 2007 | 10:49 AM
Si-Samuri's Avatar
Default Timing Belt Question???
On a d16y8 engine how tight should the timing belt be??? When i followed the manual and allowed the tensioner to self tighten it was giving me too much slack on the front (radiator side). So, i just pulled the tensioner up by hand and tightened it. Is this ok?? I know b-series guys use aftermarket tensioners to eliminate slack. Any help is appreciated???
Old Dec 17, 2007 | 12:00 PM
all-mtr-teg's Avatar
Default Re: Timing Belt Question??? (Si-Samuri)
I've been told that you should have no more than 1/4" deflection
Old Dec 17, 2007 | 12:04 PM
Si-Samuri's Avatar
I think that's about where I am at. thanks bump this up.
Old Dec 17, 2007 | 02:58 PM
Mikey3000's Avatar
how are you coming to the conclusion that its too loose? can you slide it off the gear after tensioning it? too tight is very bad, it'll break.
Old Dec 17, 2007 | 05:49 PM
Lubo_25's Avatar
Default Re: Timing Belt Question??? (all-mtr-teg)
1/4" deflection between the water pump to intake cam gear right??(dohc)
Old Dec 18, 2007 | 02:49 AM
Mikey3000's Avatar
Default Re: Timing Belt Question??? (Lubo_25)
this is a sohc
Old Dec 18, 2007 | 04:33 AM
Lubo_25's Avatar
Default Re: Timing Belt Question??? (Mikey3000)
the question applies for both engine layouts...do you check for deflection between those gears?
Old Dec 19, 2007 | 08:18 AM
Si-Samuri's Avatar
no i didnt deflection between gears. i've been driving it the way it is for 3 months. it was so loose that i could push the belt until it would touch the motor mount. in between which gears should i check?
Old Dec 19, 2007 | 10:24 AM
Mikey3000's Avatar
Default Re: (Si-Samuri)
the water pump and the cam gear. essentially the back side of the belt not the front side.
Old Dec 19, 2007 | 10:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">1/4" deflection between the water pump to intake cam gear right??(dohc)</TD></TR></TABLE>
I check both there and from the crank to the exhaust cam gear. Its usually about the same though if it tensioned correctly.
Old Dec 19, 2007 | 12:23 PM
Lubo_25's Avatar
good call teg im just getting ideas on how ppl tension their t belts and why so many expletive up from improper install
DeDonDeRosa
Apr 6, 2006 09:18 AM
Jayboy
Sep 3, 2005 03:37 PM
RCautoworks
25
Aug 15, 2004 09:17 PM
zueke
Nov 28, 2003 08:38 PM
intekragsr
Mar 25, 2003 02:12 PM
