Boost Questions
Old Dec 16, 2007 | 10:47 PM
R.I.P 2000 Si's Avatar
Default Boost Question
I justed boosted my B16A2 all stock engine at 8psi drive it for a couple of days then white smoke started coming out of the breather of the valve cover just wanted to know if anyone know about that if its normal or is my engine going to take a ****
Old Dec 16, 2007 | 10:49 PM
93egSLEEPER's Avatar
Default Re: Boost Questions (R.I.P 2000 Si)
white smoke is coolant evaporating... im not very knowledgeable on boost i run NA but i doubt thats a good thing. coolant should never be in your head.
Old Dec 17, 2007 | 12:39 AM
JDMxJEDI's Avatar
Default Re: Boost Questions (93egSLEEPER)
you probably have a blwon head gasket
Old Dec 18, 2007 | 10:56 AM
Default Re: Boost Questions (JDMxJEDI)
someone told me its the rings going ?
Old Dec 18, 2007 | 11:25 AM
95ProjectEJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.I.P 2000 Si &raquo;</TD></TR><TR><TD CLASS="quote">someone told me its the rings going ?</TD></TR></TABLE>
If its the rings then you are going to burn oil and oil usually produces black smoke.
Check your oil and see if its milky in color.
Old Dec 18, 2007 | 11:32 AM
pat92si's Avatar
Default Re: Boost Questions (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
Check your oil and see if its milky in color. </TD></TR></TABLE>
I thought burning oil was usually a blueish smoke??? not trying to be a dick or anything just saying
Old Dec 18, 2007 | 11:54 AM
hall97civic's Avatar
Default Re: Boost Questions (pat92si)
could be, but you have to be buring lots of oil to have white smoke. Check your oil level, if it is low or if the oil is turning milky in color then you definately have problems. If the oil is milky then you have a leaky head gasket which is very possible when you slap a turbo on a stock engine. If the oil level is just low and black in color, then your rings are probably bad.
Now, if the oil looks alright and isn't low, then you need to check your coolant level, and if it is low then that also means that you have a leaky headgasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER &raquo;</TD></TR><TR><TD CLASS="quote"> coolant should never be in your head.</TD></TR></TABLE>
here let me fix this for you
"coolant should never leak out of the passages in your head."
Old Dec 18, 2007 | 08:42 PM
Default Re: Boost Questions (hall97civic)
thanks guys for the answer
Old Dec 18, 2007 | 09:06 PM
luvmihatch's Avatar
yeah most def first thing i would do is stop driving the car. obviosly.. then call the shop that tuned it and c what they say BUT if it was my car id do a comp test to c if the rings are bad etc. that will aslo tell u if u are loosing compression through and thing. but id also do the head gasket asap..
ragethemachine86
Sep 16, 2006 06:43 PM
barney510
Jun 11, 2006 08:11 PM
escape2me
Jun 29, 2005 11:24 AM
aaaabbbb
Nov 3, 2004 07:23 PM
CrX-To-Tha-Max
13
Mar 10, 2004 08:25 PM
