??? Rev Hard manifold and t3/t4 4 bolt turbo!!! will it work together!!!
Old Dec 16, 2007 | 08:09 PM
GTEC913's Avatar
Default ??? Rev Hard manifold and t3/t4 4 bolt turbo!!! will it work together!!!
hey guys i have a rev hard log style manifold for a d-series. i was wondering if the rev hard manifold is compatible with a 4 bolt t3/t4 garrett turbo. the manifold is meant for a 5 bolt turbo. some people say it should work no problem but others say that it won't because it can cause leaks and make the turbo boost late... PLEASE help me out!! do i have to buy a new manifold??
Old Dec 16, 2007 | 09:35 PM
RCautoworks's Avatar
Default Re: ??? Rev Hard manifold and t3/t4 4 bolt turbo!!! will it work together!!! (GTEC913)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTEC913 &raquo;</TD></TR><TR><TD CLASS="quote">hey guys i have a rev hard log style manifold for a d-series. i was wondering if the rev hard manifold is compatible with a 4 bolt t3/t4 garrett turbo. the manifold is meant for a 5 bolt turbo. some people say it should work no problem but others say that it won't because it can cause leaks and make the turbo boost late... PLEASE help me out!! do i have to buy a new manifold??</TD></TR></TABLE>
Um, the bolt pattern on the downpipe won't cause it to leak... I'm confused.
I think, but could be wrong, one of those manifolds was designed to use a four bolt turbo ( I believe, or vice versa ) and with the wrong turbo, it runs into the block.
Old Dec 17, 2007 | 01:39 PM
TheShodan's Avatar
Moderator
Default Re: ??? Rev Hard manifold and t3/t4 4 bolt turbo!!! will it work together!!! (RCautoworks)
Rev-Hard was similar to Inline Pro for a time, they had a cast manifold for 4 bolt exhaust turbine housings and 5 bolt. The ones for 4 bolts typically were not A/C compatable, and requred the turbo to be on the other side facing the driver fender. The 5 bolt ones were made for A/C and P/S. The best way is to show a pic and compare that to Rev-Hard's website image link . That way you know for sure.
2kdrift
Mar 14, 2013 06:39 PM
dan_w_82
Feb 3, 2005 03:59 PM
BlendedEJ8
Aug 19, 2004 07:04 PM
smslude
May 2, 2003 02:01 PM
BoostinSOHC
Jul 17, 2002 10:49 AM
