Can compression test number be off due to very hot weather?
Old Jun 27, 2002 | 12:17 PM
Chubz's Avatar
Default Can compression test number be off due to very hot weather?
My engine hits 300+ psi in all cylinders (12:1). In the Northeast weather has been very hot and humid (102F). I had my car out for an hour and it felt really sluggish has to be becaue of the weather. I did a compression test and I hit 300 (cylinder 4) 300 (cylinder 3) 290 (cylinder 2) 295 (cylinder 1) I did a compression test about 2 weeks ago and I was 300 across the board. Any opinions
Old Jun 27, 2002 | 12:25 PM
sgT's Avatar
sgT
Default Re: Can compression test number be off due to very hot weather? (SuperTech)
i wouldnt worry about it
Old Jun 27, 2002 | 12:32 PM
Chubz's Avatar
Default Re: Can compression test number be off due to very hot weather? (sgT)
thanx sgt. I just like to stay on top of motor and make sure everything is ok. Do you think it could be cause of the weather?
Old Jun 27, 2002 | 12:33 PM
sgT's Avatar
sgT
i would think its possible but the numbers are still nice and high.
Old Jun 27, 2002 | 01:36 PM
Chubz's Avatar
ill ckeck either tonight or tomorrow morning when the air is a bit cooler
Old Jun 27, 2002 | 01:38 PM
uNF$@#!'s Avatar
i dont think thats big of a variance enough to be worried.
Old Jun 27, 2002 | 01:47 PM
Chubz's Avatar
I just get a bit concerned, when 2 weeks ago it was 300 psi across the board. And today its 290 and 295 two cylinders. If the rings were to go, then that variance would have been much more? Sorry to ramble, I just wasnt expecting 2 cylinders to be low.
Old Jun 27, 2002 | 01:51 PM
Black R's Avatar
25 Year Member
How are you doing the compression test?
Old Jun 27, 2002 | 01:52 PM
Chubz's Avatar
Default Re: Can compression test number be off due to very hot weather? (Black R)
From the Directions from C-speed
Old Jun 27, 2002 | 01:55 PM
uNF$@#!'s Avatar
if the rings were to go, yes, expect a much more noticeable variance,
something like 300/300/180/300 <--- cyl 3 has a problem
if your self testing expect a little changing in the number.. nothing too serious as long as you know you are properly taking the readings.
[Modified by 00-0187, 5:56 PM 6/27/2002]
Old Jun 27, 2002 | 01:58 PM
Chubz's Avatar
Default Re: Can compression test number be off due to very hot weather? (00-0187)
thanx man. My last motor went boom..trying to take care of this one.
Old Jun 27, 2002 | 01:59 PM
FSTASNTZ's Avatar
I beleive that barometric pressure does have a hand in the results of a compression test.
Jason
Old Jun 27, 2002 | 02:00 PM
Chubz's Avatar
Default Re: Can compression test number be off due to very hot weather? (FSTASNTZ)
im thinking that as well its hot and 100 percent humid making the temperature 102-105F
02BladeRider
Jul 7, 2017 05:49 AM
Brandon Peters
Oct 18, 2015 05:37 PM
sigmiester
May 2, 2007 09:58 PM
disboilikehoy
May 23, 2004 05:41 PM
Chubz
Jun 27, 2002 05:18 PM
