HUB for jdm type-r steering wheel??????
found a jdm itr steering wheel...... only problem is it has no hub... is it the same thing as a momo hub or you have to buy it staight from honda in japan or some bullsh!t ???????
anyone?
this is the back of the steering wheel.. i believe the momo hubs are 6 bolt.. this looks to be 4
http://i39.photobucket.com/alb...7.jpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itrmyke »</TD></TR><TR><TD CLASS="quote">what kind of wheel is it?
it looks like there is a 6-bolt pattern on the wheel if you omit the two holes on the extreme left and right.</TD></TR></TABLE>
did you not READ... jdm itr non-srs steering wheel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt »</TD></TR><TR><TD CLASS="quote">
did you not READ... jdm itr non-srs steering wheel</TD></TR></TABLE>
NO where did you state that it was a NON-SRS JDM steering wheel in your first post. Maybe you should be clearer in the future.
On to your question, you have purchased a piece of junk. You can not buy the hub that fits that alone. I see you have 2 options if you are intent on using that wheel. One would be to find a donor wheel that is in bad shape and swap hubs. The second would be to have something fabbed.
BTW, If you are thinking that a standard MOMO or a hub like it will work... it won't. You can see that somebody drilled holes to use a standard hub. It'll put the steering wheel postion WAY too close to the driver and the back of the wheel to me doesn't look flat enough to seat real good on one of those hubs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR »</TD></TR><TR><TD CLASS="quote">
On to your question, you have purchased a piece of junk. You can not buy the hub that fits that alone. I see you have 2 options if you are intent on using that wheel. One would be to find a donor wheel that is in bad shape and swap hubs. The second would be to have something fabbed. </TD></TR></TABLE>
btw i haven't purchased **** yet... and i never said a standard momo hub would work either.. i was asking...
btw i haven't purchased **** yet... and i never said a standard momo hub would work either.. i was asking...</TD></TR></TABLE>
SO , consider yourself informed. You're kind of rude for a 16 year old.
SO , consider yourself informed. You're kind of rude for a 16 year old. </TD></TR></TABLE>
don't know where you got 16 yr old from ... and your the one that was rude first
i dont think thats any kind of oem anything... but if u want to attach it to your vehicle somehow. buy a hub and drille some holes in your wheel. bam.
but i really dont think thats anything dc2+
thanks for the defense, guys. i can't believe i got attacked for trying to help this guy.
the wheel, by the way, does not look like an OEM JDM ITR wheel, at least not from the picture in your second post. that is why i asked what kind of wheel it was.
i think you should do some of your own research before ever trying to call someone out on their reading skills.
saving a few bucks isnt always the best way to go, this topic is a perfect example,
dont buy that piece of garbage, no matter what its just going to be ghetto, if you cant swim stay out of the water, if you cant ball....well dont try
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fullraceacura »</TD></TR><TR><TD CLASS="quote">saving a few bucks isnt always the best way to go, this topic is a perfect example,
dont buy that piece of garbage, no matter what its just going to be ghetto, if you cant swim stay out of the water, if you cant ball....well dont try</TD></TR></TABLE>
QFT!!!
Seriously, what do these things go for nowdays????? 200 tops? In any case, it's not like they are 400 like they used to be.
QFT!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itrmyke »</TD></TR><TR><TD CLASS="quote">thanks for the defense, guys. i can't believe i got attacked for trying to help this guy.
i think you should do some of your own research before ever trying to call someone out on their reading skills.</TD></TR></TABLE>
dude the wheel is oem jdm itr non srs.... i've seen it and i've had two of them before... this one just didn't have a hub and the dude was selling it cheap... so i was gonna try to find a hub for it... and i haven't bought it yet, i was gonna find a hub first... i know what the jdm itr wheel looks like, don't tell me to do my own research i know what the hell i'm doing...
as you can see i've had this wheel in most my cars...
point 1) like Comp97GSR said, you weren't exactly specific in either of your first posts. that picture -- which i took the liberty to take a look at in the hopes of helping you out -- was a bit obscure, so i had no way of knowing whether or not it was a genuine JDM Honda non-SRS wheel. unless i sat there with mine, dismantled it, and then looked at it from the rear, there would be no way for me to recognize it.
i was only trying to help you.
point 2) in no way was Comp97GSR the first one being "rude." he only suggested that you be more specific. you were the one that assumed that i didn't "READ" your post, and you were the first one to have it come to vulgarity: "...i haven't purchased SH*T yet..."
point 3) if you have so much past experience with this wheel and know so much about what you're doing, then why even post in this forum? why do you need our help if you're just going to end up being rude about it yourself?
Modified by itrmyke at 10:45 AM 12/17/2007
point 3) if you have so much past experience with this wheel and know so much about what you're doing, then why even post in this forum? why do you need our help if you're just going to end up being rude about it yourself?</TD></TR></TABLE>
X2.
X2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itrmyke »</TD></TR><TR><TD CLASS="quote">point 1) like Comp97GSR said, you weren't exactly specific in either of your first posts. that picture -- which i took the liberty to take a look at in the hopes of helping you out -- was a bit obscure, so i had no way of knowing whether or not it was a genuine JDM Honda non-SRS wheel. unless i sat there with mine, dismantled it, and then looked at it from the rear, there would be no way for me to recognize it.
Modified by itrmyke at 10:45 AM 12/17/2007</TD></TR></TABLE>
No wonder you are a tool with 96%. On troll somewhere else.
</TD></TR></TABLE>No wonder you are a tool with 96%. On troll somewhere else.
Pr-Type-R
Jun 18, 2008 08:20 AM
wifesaynogo
Nov 1, 2004 12:21 PM
Grease Monkey
Feb 17, 2004 05:48 PM
