anybody heard of this instead of a vented catch can set up?
Old Dec 15, 2007 | 07:01 PM
mkw1's Avatar
Default anybody heard of this instead of a vented catch can set up?
was talking to a guy and he said if you run a hose from the valve cover fitting to a fitting on your down pipe it will pull a vacume from the motor. getting rid of crank case pressure resulting in more power over a catch can setup ?
Old Dec 15, 2007 | 07:30 PM
97grnrs's Avatar
Default Re: anybody heard of this instead of a vented catch can set up? (mkw1)
some older cars use that setup,and some dragster type. it will work as long as ur not pulling oil out with the vapors.
Old Dec 15, 2007 | 07:36 PM
AspectIndustries's Avatar
Default Re: anybody heard of this instead of a vented catch can set up? (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">some older cars use that setup,and some dragster type. it will work as long as ur not pulling oil out with the vapors. </TD></TR></TABLE>
Yup.
I wouldnt suggest it, if your pouring oil out like crazy, but it will work nicely if you dont have oil problems.
But, the problems with check valves, etc etc etc...Who knows?
Old Dec 15, 2007 | 07:39 PM
mkw1's Avatar
Default Re: anybody heard of this instead of a vented catch can set up? (AspectIndustries)
what if you run a catch can and instead of a filter run the hose on topof the catch can to pull vacume from the tank and then still have the oil drain back?
Old Dec 15, 2007 | 08:15 PM
boostedcivicsir's Avatar
Mr. Badwrench
https://honda-tech.com/zerothread?id=1199935
Old Dec 16, 2007 | 06:44 PM
SteamedRice's Avatar
Default Re: anybody heard of this instead of a vented catch can set up? (boostedcivicsir)
thread closed! lol
BlackCatt
Jun 14, 2008 05:42 PM
alexsracing
Jan 23, 2008 06:07 PM
raphael
Mar 5, 2007 11:03 AM
MotoCARR
Feb 6, 2007 02:20 PM
flangemastermike
Jan 14, 2007 08:50 AM
