idle control valve took a crap.
Guys, I have a 92 eg civic with a 99-00 civic b16a2 swap. My IAC or idle air control decided to take a crap. I took it out, cleaned it with brake cleaner let it sit for an hour under a fan and nothing, si I am in need of an IAC Valve.
What I would like to know is, what other engine has the same Iac valve that I can pull it from and install it on b16a2 IM? Any and all help is greatly appreciated.
THANX!!!
p.s. When I cleaned it out and put it back on before I turned on the car, I had no codes in key on, engine off. The very minute I turned on the car, the light came back on. Turned off the car, checked for codes and I got code 14 which is the IAC Valve. Its the only code on right now.
THANX!!!
I just put a new one in mine too finally!!! god it was so annoying any ways. the b16a2 is the narrow bolt pattern i belive the same as mine. (r manifold). I was told 92-95 Si (d16z6) will work along with the 96+ hx or Ex civic (d16y5/d16y8) and 96+ Ls's obd2 i belive. I know for sure the d16z6 and the d16y5 works. Do you have a pic of it? Thanks
No, I don't have a picture of it. I'll try and take one though.
I'm pretty positive. I mean I pulled the code and I'm getting 14 which is IACv. I took it out, cleaned it, reset the the codes, before I turned the car on, the only code I was getting was 1 which I know already, but that was the only code, the minute I turned on the engine, a few seconds later I started getting code 14 and 1 which like I said, I know that already. I noticed that my engine started idling high at 1500 to 2000 RPM's like two weeks ago but paid no attention to it. It kept idling the same, it started to annoy me so I checked it and sure enough I got that code 14.
Is thier anything else that can trigger the IACv to crap out due to another sensor and not know about it?
Oh and I cant figure what is fitv.
cranker
Jul 10, 2010 06:05 PM
yoffer
May 31, 2007 11:54 AM
marcaobr
Nov 16, 2005 08:09 PM
Built Beast
18
Mar 26, 2005 06:14 PM
