b16b head vs b16a head how to tell apart?
Im looking to buy a b16b head w/skunk 2 stg2 cams to put on my gsr bottom end with itr pistons. Im going to use a reprogrammed p28 obd 1 ecu. first does anyone see any problems with the set-up? Is there anyway to tell the b16b head apart from the b16a. Im buying the head from someone and want to make sure its actually a b16b. thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96teggylsse »</TD></TR><TR><TD CLASS="quote">yea.. the type r head will have a stamp on it, the number should be p73... the b16a head has a different number....</TD></TR></TABLE>
I dont believe its a P73 stamp as thats ITR but even then ITR heads are stamped PR3. I know the piston code for B16B is PCT, maybe thats the head code as well.
You can not do difference between B16a and Type-R motors, they have the same CAST head...some of the differences between the two heads are that the Type-R head has a better and stronger valvetrain, the cams, lighter valves, the better intake manifold and bigger throttlebody, and a mild port job from the factory.
You can have a b16a with a port&polish and you will can not do the difference....
chaqier77
Apr 23, 2008 01:09 PM
SuPeR_MaN
12
Sep 14, 2002 06:19 PM
