99 civic ECU Problem
Old Dec 13, 2007 | 03:13 PM
Break4Gold's Avatar
Default 99 civic ECU Problem
I got a 99 Honda Civic, and i did a 97 GSR swap. And i went to get it inspected and my friend sshop and it wouldnt read anything. I was wondering it a 99 Si ECU would read better or should i use my stock ECU from the ex or would it be fucked up because its not a V Teck ECU.
Old Dec 13, 2007 | 06:23 PM
z6hatchboy's Avatar
What is your friends shop trying to read? Are you using the ecu for that motor? The 99 si one may work, idk, but i dont think the fuel maps are same (b18c1 vs b16a3?). Not sure if the stock ecu will work b/c knock sensor, and the vtec issue.
Old Dec 13, 2007 | 08:44 PM
Break4Gold's Avatar
Default Re: 99 civic ECU Problem (Break4Gold)
Yeah i got the 97 gsr computer. im not sure i figured someone else had the same problem.
I broguth it to get it inspected, and the plug in doesnt read on there computer. So i figured i needed i different ECU. Pretty much im screwed
salvagetitlesil
Mar 29, 2012 07:15 AM
send2artem
Sep 30, 2010 02:27 PM
iRIDEdumped
32
Apr 25, 2005 06:34 PM
AllMoToRB18c
Dec 9, 2003 07:45 AM
