CLUTCH QUESTIONS, PLEASE HELP
Old Dec 13, 2007 | 03:10 PM
93eh2hatch's Avatar
Default CLUTCH QUESTIONS, PLEASE HELP
i hope this isn't too confusing but.
my clutch seems to be bad but it doesn't always slip. instead of catching down by the floor, i have to release the clutch pedal more than half way out. i heard that i need a new clutch but also heard about clutch bleeding?
if you think it can be fixed by clutch bleeding how do i do this on a 93 ls hatch?
also, i have an apexi blow off valve almost new still in box for sale. 175$ any takers?
Old Dec 13, 2007 | 06:30 PM
z6hatchboy's Avatar
If it is at least slipping sometimes then its probably on its way to going out. One way to tell if your clutch needs bled is how much pressure or force the pedal has. If it seems to be a little limp lol, and you can move it with your hand fairly easy it probably needs bled. To bleed find the acuator on the tranny which pretty much the only thing you can see on it, and there a bolt with a nipple (its a 8mm on my d16) pump the pedal and open the nut a little, let some fluid/air out, close it and repeat till you have a firm pedal. but since you mention its a ls, if it has the ls tranny and its cable, then just adjust the cable. I think you have a clutch going bad though. good luck
Old Dec 13, 2007 | 07:19 PM
FarinaMotorsports's Avatar
Default Re: CLUTCH QUESTIONS, PLEASE HELP (93eh2hatch)
The fact that it slips sometimes and the pedal getting higher sounds like the clutch is going out. Time to replace it.
Old Dec 13, 2007 | 10:32 PM
93eh2hatch's Avatar
ok. i was about to replace it anyways. time for stage 2!
sounds like it needs to be bled too though. thanks a bunch
89sparks
Honda Motorcycles
May 24, 2020 05:27 AM
88crxdxfastwhip
Jun 5, 2007 01:05 PM
InitialJRift
Sep 13, 2006 10:43 AM
Simple
Sep 17, 2004 11:16 PM
Steve
Jul 23, 2001 01:42 PM
