Horn Hook up with quick release
Old Dec 13, 2007 | 02:43 PM
b18ctrb's Avatar
Default Horn Hook up with quick release
So I installed my MOMO hub and NRG quick release in my 96 EK, but I dont have a horn now Can some one please help me out??? I need to hook it up since this my daily. Thanks in advance
Old Dec 13, 2007 | 03:11 PM
92d16z6boy's Avatar
Default Re: Horn Hook up with quick release (b18ctrb)
i had a problem with this as well.. now i have no horn.
but.
i have seen some wucikrelease hubs out there that have prewire horn wires, that operate the same why the slock spring would.. (allows you to turn without binding and twisting wires.) if that doesnt work you can add a univeral button somewhere and hide it just for inspection i am going to change the srping mechanism behind the ac button on my 92 hatch to just push and release without locking on so i can wire a button up to that.
just do some research itll behoove you to do so.
goodluck
Old Dec 13, 2007 | 03:31 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ctrb &raquo;</TD></TR><TR><TD CLASS="quote"> So I installed my MOMO hub and NRG quick release in my 96 EK, but I dont have a horn now Can some one please help me out??? I need to hook it up since this my daily. Thanks in advance</TD></TR></TABLE>
merry christmas!
https://honda-tech.com/zerothread?id=1485735
https://honda-tech.com/zerothread/1887852
Old Dec 13, 2007 | 04:21 PM
b18ctrb's Avatar
Default Re: Horn Hook up with quick release (philosofy1)
Thanks, but I think the wiring for the EK might be a little different if Im not wrong?
Old Dec 14, 2007 | 08:08 AM
monicle's Avatar
all you need to do is take the horn wire and connect it to one of the tabs on the back of the nrg release, then take the other tab and ground it to the quick release body using one of the rings that should have come with the quick release.
Old Dec 14, 2007 | 11:26 AM
b18ctrb's Avatar
Default Re: Horn Hook up with quick release (monicle)
Do I have to take the horn wiring off of the back of the air bag?
Old Dec 14, 2007 | 12:26 PM
monicle's Avatar
unless you removed the wire spool from the steering column it should be right there. big brown wire
Old Dec 14, 2007 | 12:33 PM
trev0006's Avatar
* B A N N E D *
Thanks for the tips.
Old Dec 15, 2007 | 07:35 PM
b18ctrb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">unless you removed the wire spool from the steering column it should be right there. big brown wire
All I removed was the SRS unit and OEM wheel
Old Jan 15, 2008 | 08:17 PM
ekhatchey's Avatar
the horn wire is connected to the srs unit there are 2 connectors one for srs and another for the horn and cruise control.
the one with the yellow connector is for the srs the other one is gray. the wires coming into the connector from the harness is gray the one going to the srs unit on mine and according to the service manual is blue with a green stripe for the horn.
all you have to do is attach an electrical splicer about an inch below the connector that is supposed to go into the srs unit from there add a female spade connector to approximently 6 inches of wire and run up underneath the colum and ignition use a wire clamp to secure the wire firmly to the colum using the exsisting srs mounting brackets. from the spade connector use a flat pen top arm straightened out u may want to bend it so it has a little bit of pressure pointed in the direction of the hub. once the wire and spade connector are secure push the pen arm under the hub for contact then ur done. if you wired it correctly u should be able to put ur steering wheel on and the horn should work. if you have any problems with this install send me a message and ill try to help you as best i can. i just did this to my 96 works like a champ just need a new louder horn.
i will be taking pictures this weekend so keep your eyes open
Modified by camarine2003 at 7:58 AM 1/16/2008
Old Jan 16, 2008 | 07:09 AM
b18ctrb's Avatar
Default Re: (camarine2003)
Thanks for the tips. But I know pics will be a lot more help to me. Im one of those visual learing guys. Like to see how its done
jiggatone
Feb 10, 2008 12:48 PM
ekk41
Oct 10, 2007 05:32 AM
ozzyman
Northwest (Sales)
Jun 25, 2006 03:14 PM
SuperSi
26
Jun 2, 2006 05:18 PM
johnny hatchback
Apr 1, 2003 12:50 AM
