Valvoline Syn Power Fully Synth 75W-85 GL-4 Transmission Fluid??? Will it be ok???
Old Dec 13, 2007 | 02:15 PM
Adamd's Avatar
Default Valvoline Syn Power Fully Synth 75W-85 GL-4 Transmission Fluid??? Will it be ok???
Found 2 Litres of this stuff floatin about and she's due a change, will this be ok???
(DC2 Type R - 2000 model - 87,000 miles)
Thanks in advance people, Lee.
Old Dec 13, 2007 | 03:50 PM
jdmscg's Avatar
No Sales Forums
Default Re: Valvoline Syn Power Fully Synth 75W-85 GL-4 Transmission Fluid??? Will it be ok??? (Adamd)
I wouldn't advise it...The synthetic would be to slick and Honda recommends their Manual Transmission fluid and only to use 10w30 or 10w40 motor oil as a temporary replacement, seeing that is doesnt have the proper addititves, and continued use can cause stiffer shifting
Old Dec 13, 2007 | 03:52 PM
The Dude's Avatar
Banned
x2
L.S.D.'s gotta have the right additives.
Old Dec 13, 2007 | 05:18 PM
B18CXr's Avatar
x2
Ignore the above statement, but stay with OEM Honda fluid.
Old Dec 13, 2007 | 05:59 PM
94rs-turbo's Avatar
im throwing gm syncromesh friction modified out there
But yeah way too heavy weight for your tranny
Old Dec 13, 2007 | 06:12 PM
RagingAngel's Avatar
Default Re: (The Dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Dude &raquo;</TD></TR><TR><TD CLASS="quote">x2
L.S.D.'s gotta have the right additives.</TD></TR></TABLE>
no it doesn't...it's not a clutch pack LSD.
75W-90 gear oil would be roughly equivalent to a 10W-40 engine oil
80W-90 gear oil would be roughly equivalent to a 20W-40 engine oil
80W gear oil would be roughly equivalent to a straight 20 engine oil
http://www.gasgasrider.com/htm....html
Honda recently went with a weight that's similar to 5W30 but their previous blend was more like 10W30. Some people see the 75W90 and immediately think it's like molasses or something.
To the OP: Unless you are unable to get Honda MTF for whatever strange reason, or you are running a specific type of clutch pack LSD - stick with what others have said.... Honda MTF.
FWIW, I use a 50/50 mix of GM sync and the old Honda MTF because I have a couple of boxes of it laying around.... works good
Old Dec 13, 2007 | 06:17 PM
94rs-turbo's Avatar
Default Re: (RagingAngel)
good info i didnt know it was ok to mix fluids
Old Dec 13, 2007 | 06:41 PM
The Dude's Avatar
Banned
Default Re: (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">x2
Ignore the above statement, but stay with OEM Honda fluid.</TD></TR></TABLE>
OEM fluid does have the right additives built in. Red Line for example doesn't. You'll get YOWWWLLLLLLL every time you back out of parking spot. I put the OEM MTF back in.
Old Dec 13, 2007 | 06:53 PM
OEM fluid does have the right additives built in. Red Line for example doesn't. You'll get YOWWWLLLLLLL every time you back out of parking spot. I put the OEM MTF back in. </TD></TR></TABLE>
I don't know which redline fluid you were using, but it must have been the MT90 which is not recommended.
The MTL is what I used before with a clutch pack and it worked beautifully. The yowl you speak of is likely not related to the LSD as it is a mechanical unit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlineoil &raquo;</TD></TR><TR><TD CLASS="quote">
This 70W80 GL-4 Gear Oil (SAE 5W30/10W30 engine oil viscosity) is designed for use in manual transmissions and transaxles. Provides excellent protection of gears and synchronizers and its balanced slipperiness provides a perfect coefficient of friction, allowing easier shifting. Popular in many BMW transmissions and in most Honda and Acura transaxle applications.</TD></TR></TABLE>
But with that said, it will still vary from user to user which is why others will swear by syncromesh over OEM or Redline etc.
Old Dec 13, 2007 | 07:09 PM
The Dude's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
But with that said, it will still vary from user to user which is why others will swear by syncromesh over OEM or Redline etc.</TD></TR></TABLE>
Well the MTL was what I did try. Redline recomends "Limited-slip transaxles may require the 75W90 Gear Oil to
prevent limited-slip chatter." But after telling th' import shop 3 times that ITRs had LSDs, they put MTL in. ACURA put the OEM fluid back in and told me what I related above and noise was gone. Most Honda and Acura trans. don't have LSDs.
http://www.redlineoil.com/pdf/6.pdf
Modified by The Dude at 10:35 PM 12/13/2007
Old Dec 13, 2007 | 07:32 PM
vinuneuro's Avatar
Be careful with gear oil. A lot of them are not compatible with the brass parts used in our trans'.
Old Dec 13, 2007 | 07:38 PM
The Dude's Avatar
Banned
Default Re: (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">Be careful with gear oil. A lot of them are not compatible with the brass parts used in our trans'.</TD></TR></TABLE>
I did recomend the OEM MTF.
DC5RK20A's Avatar
Honda is up to MTF3 now here in Japan. I think the Honda/Acura dealers there finally started carrying the MTF2 (true tranny fluid). The original Honda MTF was essentially just a 5 or 10W30 motor oil. I haven't seen first hand as I haven't been in the US for many, many years but apparently most dealers just filled the tranny cases with straight motor oil there.
The helical slip doesn't need any special fluids, hence the reason why that import shop used the MTL and not the 75-90 fluid. The LSD's that Redline are referring to are clutch pack types, very different from a helical unit.
Old Dec 13, 2007 | 07:39 PM
vinuneuro's Avatar
I did recomend the OEM MTF.</TD></TR></TABLE>
I didn't mean to direct it at you. General fyi.
Old Dec 13, 2007 | 08:24 PM
The Dude's Avatar
Banned
Yah, yah, no prob. This subject has lots of ins n' outs. To add, my experiance above was right after break in and a baseline dyno. I was trying to reuce friction in trans and pick up a free horse or two but had the problems with the LSD and MTL so it didn't work out for me.
Old Dec 13, 2007 | 09:57 PM
Bbasso's Avatar
Default Re:
There is only one simple answer, Honda's MTF.Cheap enough to change frequently. No need for discussion.
Old Dec 14, 2007 | 02:53 AM
an2ny888's Avatar
Default Re: Re: (Bbasso)
i wonder how our local mtf compares to the mtf3?
Old Dec 14, 2007 | 08:55 AM
98 ITR's Avatar
I know preferences vary from user to user, but I switched from the MTL to MT90 years ago and will never go back.
The MTL is way too light, and resulted in notchy shifting, among other issues. Plus an overall feel that the gears were not lubricated enough, especially when hot. The MT90 quickly rectified those problems.
Both my mechanic and I (he runs a race spec CRX in the Canada GT Touring Championship class) switched to the MT90 and have been singing its praises ever since. This is on both a street/circuit ITR and a track only professional race car ... both with the same tranny, except he uses carbon synchros.
I have tried both the MTL and MT90 on a used ITR tranny and a freshly rebuilt one, and the MT90 outperformed the MTL in every aspect. I will never use the MTL again. Too light, too slick.
Both my Mechanic and I have been using the MT90 for a few years now, and both transmissions are in fantastic shape and run beautifully. Longevity is not an issue with the MT90 whatsoever. Both of our transmissions have been dismantled and inspected this summer, and all gears, bearings, and LSD unit are in top shape.
Once again though, personal preference.
Old Dec 14, 2007 | 09:02 AM
Dave_B's Avatar
&lt;---- Amsoil user here... Alrready has syncromesh in it.
I know Walker users it too...
Old Apr 25, 2008 | 09:19 PM
acmoc's Avatar
FWIW, I use a 50/50 mix of GM sync and the old Honda MTF because I have a couple of boxes of it laying around.... works good </TD></TR></TABLE>
?... I thought gear oil was for differentials and stuff, isn't it bad for your tranny. I'm pretty sure it'll do some damage
Old Apr 25, 2008 | 09:38 PM
SickBlackAck's Avatar
It would work, but I wouldn't put it in my tranny, I'd rather use honda atf or mtf
L8APX
Apr 3, 2008 03:42 PM
dc5 kid
12
Nov 2, 2007 12:17 PM
Matt00
Sep 26, 2005 01:50 PM
1bad16v
Mar 7, 2005 07:32 AM
TypeR1558
Dec 18, 2002 02:30 AM
