help, car has very rough start then oil coming out of filter.
Old Dec 13, 2007 | 10:56 AM
K i l l a B e e.'s Avatar
Default help, car has very rough start then oil coming out of filter.
So i removed my turbo kit, and put everything back to stock, now when i start my car, it has a very rough start and when i finally get it to start, oil spills out from what looks to be the oil filter. what can be wrong? I dont think it can be the filter leaking.
Old Dec 13, 2007 | 10:58 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: help, car has very rough start then oil coming out of filter. (K i l l a B e e.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K i l l a B e e. &raquo;</TD></TR><TR><TD CLASS="quote"> oil spills out from what looks to be the oil filter. what can be wrong? I dont think it can be the filter leaking.</TD></TR></TABLE>
Why not the filter?
Old Dec 13, 2007 | 11:01 AM
Default Re: help, car has very rough start then oil coming out of filter. (mcvtec)
hmm. i screwed it in tight, and the oil is leaking a steady amount. a solid drip line.
Old Dec 13, 2007 | 11:05 AM
BryanM.'s Avatar
Resident Gearhead
Look at the filter you took off (if you can). Does it have it's gasket? If not you know where it is...
Old Dec 13, 2007 | 11:08 AM
man, it sucks because i started up my car, and i was letting it warm up whe ni see this huge puddle underneath it, and i thought to myself.. hmm it didnt rain. Turns out it was all oil!
Old Dec 13, 2007 | 11:13 AM
darkclark's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">Look at the filter you took off (if you can). Does it have it's gasket? If not you know where it is...</TD></TR></TABLE>
he is saying when you changed you filter you left the o-ring from the old one if this happens it will leak
also how was your oil feed to the turbo run was it a sandwhich plate maybe you removed the feed line from the plate and did not plug the hole?
Old Dec 13, 2007 | 11:14 AM
Default Re: help, car has very rough start then oil coming out of filter. (darkclark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkclark &raquo;</TD></TR><TR><TD CLASS="quote">
also how was your oil feed to the turbo run was it a sandwhich plate maybe you removed the feed line from the plate and did not plug the hole?</TD></TR></TABLE>
i removed everything and just plugged the oil pressure sensor back into the block.
Old Dec 13, 2007 | 11:31 AM
fmrprojects's Avatar
gotta be the oil pressure switch or the filter was double gasket. did you run a sandwich on the filter for the turboline?
Old Dec 13, 2007 | 11:55 AM
blk92_d16's Avatar
^Exactly! Do you use Teflon tape on the oil switch? Please do examine more closely to see which of the two the oil is coming from.
BTW, when I bought my '92 VX and did the first oil change I did accidentally double O-ring the filter. The dang old, old, old filter left its O-ring behind and I didn't see it from above the motor as I screwed on the new one.
Good luck!
fatboy1185
Jun 4, 2010 11:06 PM
r33dm0n3y
Jun 23, 2009 05:30 PM
00ls1
Aug 1, 2008 07:48 PM
vtech_tuner
Aug 7, 2005 09:37 PM
Mover
Feb 20, 2003 09:21 AM
