Windshield Wiper motor replacement
Old Dec 12, 2007 | 07:31 PM
macrohard's Avatar
Default Windshield Wiper motor replacement
How do you replace the window wiper motor on a 97 honda civic. I unbolted everything and it still won't come out. I don't have a manual and wanted to ask before I go a buy one. Thanks.
Old Dec 12, 2007 | 07:37 PM
EG2Driver's Avatar
Default Re: Windshield Wiper motor replacement (macrohard)
what exactly did you undo, the arms or the motor itself? They're probably stuck in from rust or age, try pulling on them gently.
Old Dec 12, 2007 | 07:48 PM
macrohard's Avatar
Default Re: Windshield Wiper motor replacement (EG2Driver)
I first took off the arms then took off the bolts to the motor itself. I'm pretty sure it's just a pull out and replace kind of thing, but for the life of me, the motor won't come out. I just want to know if I got all the bolts out. If nothing works, I will just go buy a repair manual. I need one anyways.
Old Dec 12, 2007 | 07:51 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by macrohard &raquo;</TD></TR><TR><TD CLASS="quote">I first took off the arms then took off the bolts to the motor itself. I'm pretty sure it's just a pull out and replace kind of thing, but for the life of me, the motor won't come out. I just want to know if I got all the bolts out. If nothing works, I will just go buy a repair manual. I need one anyways.</TD></TR></TABLE>
So you removed the wiper cowel and loosened the four 10mm bolts that hold the wiper assembly to the car? Did you also unplug the huge electrical connector? If you've done these things, you can just pull and wiggle until it comes out.
Old Dec 12, 2007 | 07:54 PM
3lo's Avatar
3lo
here is from the manual
Old Dec 12, 2007 | 07:58 PM
macrohard's Avatar
Default Re: (3lo)
Thank you very much.
Old Dec 13, 2007 | 01:57 AM
NOFX's Avatar
H-T White Ops
Before you remove the linkage, mark on the motor and linkage so you can line them up later.
If the wipers seem to work backwards when they're all hooked up, it's because the linkage is on wrong.
TheGut
K Series
Jul 11, 2011 06:34 AM
Bonesz36
Sep 13, 2008 02:07 PM
onepoint-gsr
Jun 3, 2007 09:11 AM
Markis.
Nov 19, 2005 09:47 AM
^Sammy]!.
Dec 29, 2003 06:32 PM
