will a ls throttle body fit my b16a ?
Old Dec 12, 2007 | 06:27 AM
nefariousyellow's Avatar
Default will a ls throttle body fit my b16a ?
The reason I am asking is because my b16a (OBD0) has a messed up FITV, and I cant find one to replace it. So someone suggested changing the throttle body, and my friend has a ls one sitting around. Will it bolt right on?
Old Dec 12, 2007 | 04:21 PM
Default Re: will a ls throttle body fit my b16a ? (nefariousyellow)
Anyone ?
Old Dec 12, 2007 | 04:23 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nefariousyellow &raquo;</TD></TR><TR><TD CLASS="quote">The reason I am asking is because my b16a (OBD0) has a messed up FITV, and I cant find one to replace it. So someone suggested changing the throttle body, and my friend has a ls one sitting around. Will it bolt right on?</TD></TR></TABLE>
why replace the whole throttle body if your FITV is bad, why not replace the FITV from the ls to the b16? alot less work.
Old Dec 12, 2007 | 04:36 PM
Default Re: will a ls throttle body fit my b16a ? (philosofy1)
Well, because it's an OBD0. I can't find one for it. So I've been told to upgrade the throttle body to an OBD1, which will be easier to replace FITV, if needed.
Old Dec 13, 2007 | 03:27 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nefariousyellow &raquo;</TD></TR><TR><TD CLASS="quote">Well, because it's an OBD0. I can't find one for it. So I've been told to upgrade the throttle body to an OBD1, which will be easier to replace FITV, if needed.</TD></TR></TABLE>
, sorry, i guess i missed that part.
Old Dec 15, 2007 | 10:53 PM
any ideas?
Old Dec 15, 2007 | 11:23 PM
byronl's Avatar
my buddy with a obd0 b16 put on a obd1 ls throttle body on his b16. I'm not exactly sure what he did but I know some wiring had to b done for his map sensor maybe because it was already messed up or something. But it can be done.
Old Dec 16, 2007 | 02:09 AM
sharik's Avatar
well the throttle body will bolt up, but the electronics of it i don't know about?
Old Dec 16, 2007 | 04:41 AM
blackeg's Avatar
Default Re: (sharik)
yeah it will bolt up.
i think the plugs are the same as well, and you can run the map sensor either on the firewall or on top of the throttle body
Old Dec 16, 2007 | 08:17 AM
19ekcoupe96's Avatar
Default Re: (blackeg)
why not jus clean the fitv?? would save u the work of rippin the throttle body off.....
Old Dec 16, 2007 | 08:29 AM
fmrprojects's Avatar
Default Re: (19ekcoupe96)
what car is this in? if its in a obd-1 car and you running obd-o stuff, might as well change it out to a obd-1 throttle body and manifold
Old Dec 16, 2007 | 08:41 AM
WhiteEkCivic's Avatar
Default Re: (fmrprojects)
It will Fit but the ls throttle body is a little bit smaller. I just put a b16 throttle body on my b20 and it pulls a little harder so u might lose a little bit of power.
jamtwo92cx
Feb 2, 2008 03:31 AM
SupaFly_Honda
Jan 9, 2005 07:11 PM
Got Milk
21
Dec 28, 2004 01:05 PM
