will a ls throttle body fit my b16a ?
The reason I am asking is because my b16a (OBD0) has a messed up FITV, and I cant find one to replace it. So someone suggested changing the throttle body, and my friend has a ls one sitting around. Will it bolt right on?
Re: will a ls throttle body fit my b16a ? (nefariousyellow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nefariousyellow »</TD></TR><TR><TD CLASS="quote">The reason I am asking is because my b16a (OBD0) has a messed up FITV, and I cant find one to replace it. So someone suggested changing the throttle body, and my friend has a ls one sitting around. Will it bolt right on?</TD></TR></TABLE>
why replace the whole throttle body if your FITV is bad, why not replace the FITV from the ls to the b16? alot less work.
Re: will a ls throttle body fit my b16a ? (philosofy1)
Well, because it's an OBD0. I can't find one for it. So I've been told to upgrade the throttle body to an OBD1, which will be easier to replace FITV, if needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nefariousyellow »</TD></TR><TR><TD CLASS="quote">Well, because it's an OBD0. I can't find one for it. So I've been told to upgrade the throttle body to an OBD1, which will be easier to replace FITV, if needed.</TD></TR></TABLE>
, sorry, i guess i missed that part.
my buddy with a obd0 b16 put on a obd1 ls throttle body on his b16. I'm not exactly sure what he did but I know some wiring had to b done for his map sensor maybe because it was already messed up or something. But it can be done.
Re: (19ekcoupe96)
what car is this in? if its in a obd-1 car and you running obd-o stuff, might as well change it out to a obd-1 throttle body and manifold
Re: (fmrprojects)
It will Fit but the ls throttle body is a little bit smaller. I just put a b16 throttle body on my b20 and it pulls a little harder so u might lose a little bit of power.
