Optimal Vtec X-over point??
Old Jun 26, 2002 | 11:59 PM
DualKnuttz's Avatar
Banned
Default Optimal Vtec X-over point??
What is a good or optimal Vtec crossover point for an LS/Vtec setup with B16a trans? I currently have it set at 5k and I think it should be higher. Does anybody agree with me or does anybody have any suggestions?
Old Jun 27, 2002 | 12:02 AM
Vanilla4215's Avatar
Default Re: Optimal Vtec X-over point?? (DualKnuttz)
I was wondering the same thing, but for a CRVTEC with a B16 tranny and some 11:1 compression pistons. I don't think you can acuratelly tell someone a certain crossover point. All motor are built differently, especially frankentein motors. All I could say would be take it too a dyno, and TUNE TUNE TUNE!
Old Jun 27, 2002 | 04:58 AM
hybridreams's Avatar
Default Re: Optimal Vtec X-over point?? (Vanilla4215)
Yup, depends on your setup and the tuning.
Old Jun 27, 2002 | 05:58 AM
Doctor CorteZ's Avatar
what cams , thats what really changes where your optimal x-over is gonna be
do this - on the V-tec controller do a pull with the x-over set as low as it goes , what is that like 3k
- next do a pull with the highest point avail.
- overlap the graphs and you will be close to the optimal point where they intersect , then fine tune on the dyno from there
Old Feb 22, 2003 | 10:53 AM
kHoA DoGG's Avatar
Default Re: Optimal Vtec X-over point?? (Doctor CorteZ)
how can you set the vtec controller to do pulls so you can overlap the graphs? I thought only dynos could graph this?
Old Feb 22, 2003 | 11:32 AM
@irborne's Avatar
IMO: i would say stick w/ 5k if your rev-limit at about 8k. on the other hand, if you can rev up to ~9k redline at 6k would be optimal.
Old Feb 22, 2003 | 11:35 AM
dfoxengr's Avatar
Default Re: Optimal Vtec X-over point?? (sNoOziN' EF8)
he meant pull on the dyno with ur controller set at lowest and highest points...then overlap
Old Feb 22, 2003 | 12:03 PM
rodrez.'s Avatar
It's all about the tuning. Although the crossover might feel "strong" at 5,000 rpm, you could be giving up power that you didn't know about. Using a dyno to adjust fuel, cam timing, crossover, etc can have a HUGE impact on performance.
Old Feb 22, 2003 | 12:56 PM
kHoA DoGG's Avatar
Default Re: Optimal Vtec X-over point?? (hybridvteceg)
exactly what I was trying to say. Is this possible?
Old Feb 22, 2003 | 01:38 PM
gamby's Avatar
It's very possible. After tons of experimenting, the dyno showed that my ideal x-over was @ 5500 rpm.
It's different for every engine, though. No substitute for hard dyno #'s.
Old Feb 22, 2003 | 01:56 PM
SpoolinSol's Avatar
Default Re: Optimal Vtec X-over point?? (gamby)
5500
stock crossover
Old Feb 22, 2003 | 02:11 PM
NitrousEK's Avatar
What kind of cams are your running???
Old Feb 22, 2003 | 02:25 PM
kHoA DoGG's Avatar
Default Re: Optimal Vtec X-over point?? (NitrousEK)
i have stock cams. I thank all you peeps for the feedback but what I was trying to say was, would the VAFC controller show the graphs and allow me to overlap? I'm trying to get some raw tuning w/o a dyno.
TurboEG6262
Mar 8, 2013 12:39 PM
honda_ek9
14
Jun 7, 2009 04:42 PM
chulopilong
Jul 25, 2004 07:10 AM
turbodsmpower
Mar 29, 2003 04:25 PM
