LS build on 4Dr any suggestions
Old Dec 11, 2007 | 09:13 AM
integgy94's Avatar
Default LS build on 4Dr any suggestions
Well, I just bought a 4Dr integra for $300.00 now looking to start fresh as a project car. Only concern is weight of car. I've been reading and searching for the last three days trying to get a good idea of what I should put in. I'm leaning more towards fully built B18B. Bought a B18B long block for $800.00 Now Just need some suggestions on what would be a good set up for a 4DR. Any help would be appreciated...
Old Dec 11, 2007 | 09:18 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: LS build on 4Dr any suggestions (integgy94)
Some might say LS/VTEC, and most will say boost...
Get your block built, look for a head, and boost that bish!!!
Oh yeah, Welcome to The Addiction...
Old Dec 11, 2007 | 09:22 AM
integgy94's Avatar
Default Re: LS build on 4Dr any suggestions (Byaaah!)
The only reason I dont want to Go Ls Vtec is because I dont trust any of the shops where I am to get that ish done. I know SOHC motors like the back of my hand but DOHC are a bit different and I dont want to mess something up trying to build something like that. plus i'm working with a $2,500.00 buget right now. Prices are not cheap for a B16 or GSR head where I am unless you find it on the streets and odds are it's messed up.
Old Dec 11, 2007 | 10:00 AM
AWD Terror's Avatar
for that much, you could get a good used greddy kit with a tune.
Old Dec 12, 2007 | 09:39 AM
integgy94's Avatar
Default Re: LS build on 4Dr any suggestions (AWD Terror)
Still trying to find a good place to buy all the parts I need for this LS Build. Any help on a good place with good prices would be a big help. Looking for the following parts.
*Lightwieght Crankshaft.
*Rods & pistons
*Main bearings
*Pistons
*Entire Valvetrain
*Performance intake manifold
*Gasket sets
*cam gears
*ARP rod bolts
*ARP head studs
*Turbo set up capable of 18PSI
*Turbo timer
*and chipped LS ECU
Any help for good prices and a good place to buy would be highly appreciated
Old Dec 12, 2007 | 09:47 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integgy94 &raquo;</TD></TR><TR><TD CLASS="quote">*Turbo set up capable of 18PSI</TD></TR></TABLE>
Stop going by PSI. It does not matter.
You need to have a HP goal.
You keep saying 4dr like it matters. I'll let you in on a little secret.....4drs have the same drivetrain as 2drs.
Old Dec 12, 2007 | 04:10 PM
integgy94's Avatar
Well, im aiming at 320HP... I know that the drivetrain is the same its just where I live everyone refers to a 4dr as a 4dr. Not an integra ls or whatever if it has 4dr out here you refer to it that way. So I got use to it.
Old Dec 13, 2007 | 04:15 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integgy94 &raquo;</TD></TR><TR><TD CLASS="quote">Well, im aiming at 320HP... I know that the drivetrain is the same its just where I live everyone refers to a 4dr as a 4dr. Not an integra ls or whatever if it has 4dr out here you refer to it that way. So I got use to it.</TD></TR></TABLE>
Look into the gt series. With 320 as your goal, you could get a turbo that hits full boost around 3k-3.5k
Old Dec 13, 2007 | 04:49 AM
jhammond_82's Avatar
Reject Papi
$2500 is a decent amount to start with. why not check online for a b16, or a gsr swap, there are all kinds of companies that sell them. i wouldn't worry about local, try, http://www.tigerjapanese.com, they always have swaps for sale. 4dr=
Old Dec 13, 2007 | 05:07 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: LS build on 4Dr any suggestions (jhammond_82)
build and boost the b18b
Old Dec 13, 2007 | 06:34 AM
integtegluver's Avatar
if u can get a hold of a gsr i would do it but if nothin else do the ls
Old Dec 13, 2007 | 07:41 AM
integgy94's Avatar
Default Re: LS build on 4Dr any suggestions (integtegluver)
I wanna run non-VTec. I dont like the whole thing of DOHC VTec. I know everything to build a SOHC VTec but not DOHC. everyone out here is running GSRs, B16s, H22's and all that. I want my ish to be different. That's why im leaing on the Built LS boost.
Old Dec 13, 2007 | 07:45 AM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integgy94 &raquo;</TD></TR><TR><TD CLASS="quote"> I dont like the whole thing of DOHC VTec. I know everything to build a SOHC VTec but not DOHC. .</TD></TR></TABLE>
this makes no sense, while i commend you on wanting to be different
Old Dec 13, 2007 | 08:44 AM
integgy94's Avatar
Default Re: LS build on 4Dr any suggestions (GRAF-FITI)
Not you bro. Ol bou above you said with $2500.00 I could go get a B16 or GSR and such.
An what does Gt series mean???
youngyankee585
Sep 11, 2013 05:39 AM
uses0ap
Mar 30, 2009 09:31 AM
w0ng_sta
Apr 30, 2006 02:28 PM
spoonspec
Mar 12, 2004 04:52 PM
95redcivicex
Sep 16, 2002 08:45 PM
