car bogs alot , idles low no power after im gasket replacement
Old Dec 11, 2007 | 06:24 AM
preludeboybmw's Avatar
Default car bogs alot , idles low no power after im gasket replacement
ok i had 1.6 in my 94 ex and replaced it with a d15 , with ecu and distributor just put all new plugs , wires , oil . starts up fine , after it warms up and i start driving it bogs alot when i press on pedal , for some reason if u press the gas very slow it gets up to speed with no bog , but if i floor it it just bogs all the way to redline , some times is sounds like a gocart . ALSO i replaced the tps becasue old one broke swtiching tb from the 1.6 vtec to the 1.5 , also no CEL .
Old Dec 11, 2007 | 07:50 AM
bump
Old Dec 11, 2007 | 09:15 AM
93egSLEEPER's Avatar
Default Re: car bogs alot , idles low no power after im gasket replacement (preludeboybmw)
retime it would be a start. then check to make sure you have no air leaks.
Old Dec 11, 2007 | 03:33 PM
fixed!! one of hte spark plug wires was bad...even tho its was new....how gay
Supa_Slow_Ej1
29
Jul 25, 2012 05:18 PM
fsl
Classic Hondas
Jul 17, 2012 06:50 PM
turboteg90
10
Sep 19, 2008 01:06 PM
plastik462003
Oct 24, 2003 01:10 PM
