car bogs alot , idles low no power after im gasket replacement
ok i had 1.6 in my 94 ex and replaced it with a d15 , with ecu and distributor just put all new plugs , wires , oil . starts up fine , after it warms up and i start driving it bogs alot when i press on pedal , for some reason if u press the gas very slow it gets up to speed with no bog , but if i floor it it just bogs all the way to redline , some times is sounds like a gocart . ALSO i replaced the tps becasue old one broke swtiching tb from the 1.6 vtec to the 1.5 , also no CEL .
Re: car bogs alot , idles low no power after im gasket replacement (preludeboybmw)
retime it would be a start. then check to make sure you have no air leaks.
Supa_Slow_Ej1
29
07-25-2012 05:18 PM
fsl
Classic Hondas
07-17-2012 06:50 PM
turboteg90
10
09-19-2008 01:06 PM
