SOHC VTEC REV LIMIT?
Old Dec 11, 2007 | 05:12 AM
redb16coupe's Avatar
Default SOHC VTEC REV LIMIT?
I GOT D15B DUAL VTEC MOTOR IN MY COUPE I JUST FINISHED PUTTING IN AN LSD TRANS ON IT AND NOW I HAVE TO DO SOMETHING BOUT THE ECU. I HAVE A STOCK PO6 WITH THE OBD2 TO OBD1 HARNESS. BUT WHAT IM WONDERING IS WAT REV LIMIT SHOULD I SET THE ECU TO? AN EX IS STARTS REDLINE AT 7000 MINE CUTS AT SEVEN NOW AND IT WANTS MORE BUT ITS STOCK I DONT WANNA BEND A VALVE ANY IDEAS WOULD BE GREAT..
Old Dec 11, 2007 | 05:38 AM
z6hatchboy's Avatar
Well, d16/d15s dont reallly make power past 7200 anyways in stock form, so id say 7500-7800
Old Dec 11, 2007 | 05:41 AM
Default Re: (z6hatchboy)
IT USED TO HAVE A LONG GEAR TRANNY ON IT AND WAS A SLUG I JUST PUT THIS TRANNY LAST NIGHT AND IT WAS A NIGHT AND DAY DIFFERENCE, AND THE PO6 CUTS RIGHT AT 7000 SO YEA CHIP HERE I COME, PLUS IM POPPING VTEC WITH A PUSH BUTTON. WHICH SUCKS WHEN YOUR TRYING TO SHIFT AT THE SAME TIME
Old Dec 11, 2007 | 06:10 AM
Adamlx's Avatar
I would say more like 6800..........but w/e rev er to 10!!
Old Dec 11, 2007 | 06:42 AM
Default Re: (Adamlx)
SO WAT SHOULD I DO 7800 OR WAT CUZ IT DOESNT FEEL TO ITS FULL POTENTIONAL AT 7000 ITS NOT WHERE ITS SUPPOSED TO BE
Old Dec 11, 2007 | 07:32 AM
ddd4114's Avatar
Default Re: (redb16coupe)
1) Turn off caps lock.
2) Your engine's redline is 7200 rpm.
Old Dec 11, 2007 | 07:40 AM
SOHC_4dr's Avatar
you should stay at OEM limit. unless your going to build it to handle 9-10 grand
96 EX's Avatar
Default Re: (ddd4114)
The redline for that should be like 7200 rpms if you dont have upgraded valvetrain and a cam then its worthless to take it past that seeing as you wont make any more power doing so.
Old Dec 11, 2007 | 08:59 AM
homemadeturbo's Avatar
Default Re: (96 EX)
It doesn't feel right because you're activating the vtec solenoid with a button and still running on the low cam fuel/timing maps, dumbass.
Old Dec 11, 2007 | 09:08 AM
93egSLEEPER's Avatar
Default Re: (homemadeturbo)
SOHC VTEC doesnt do a whole lat to begin with.
Old Dec 11, 2007 | 09:15 AM
95ProjectEJ1's Avatar
Default Re:
If only this forum was like the wheel/tired forum... people would lose % left and right for half of the ish they post up.
Old Dec 11, 2007 | 09:36 AM
Syndacate's Avatar
Default Re: Re: (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">Well, d16/d15s dont reallly make power past 7200 anyways in stock form, so id say 7500-7800</TD></TR></TABLE>
They really don't make any power past 7k..I'd set the rev limiter at 7200 - you should be shifting right b4 the needle hits 7 anyway.
Old Dec 11, 2007 | 09:59 AM
Thanks for the replys, i guess 7200 it will be
Tong.Y
10
Jul 29, 2010 11:48 AM
sulib16
Oct 8, 2006 04:25 PM
RACING INTEGRATION
Feb 5, 2005 01:42 PM
lohatch
10
Nov 11, 2003 11:10 AM
B00STED2
Oct 30, 2003 05:04 PM
