hybrid tranny help!
Old Dec 10, 2007 | 10:56 PM
dc2leftovers's Avatar
Default hybrid tranny help!
i was curious if anyone knew if it is possible to put hydro gsr gears and an aftermarket LSD out of a cable LS trans all into a ys1 case?
Old Dec 10, 2007 | 11:22 PM
snm95ls's Avatar
Default Re: hybrid tranny help! (dc2leftovers)
yes.
Sort of.
The ring gear for the cable ls has a different bolt pattern than the GSR ring gear. Therefore it won't fit the LSD. Since the LS and GSR have different final drive ratios, you would have to use the LS FD with the GSR gearset in order to use that LSD.
So, in order to retain the 4.4 final drive of the GSR, you would need a ring gear form a 92-93 GSR or possibly a cable b16 trans. Not sure about the latter choice though.
I do have a 4.4 ring gear that would work with the LS LSD though.
Old Dec 10, 2007 | 11:28 PM
Default Re: hybrid tranny help! (snm95ls)
if i were to use the ls fd how much and in what way do you think it would affect the gearing?
Old Dec 10, 2007 | 11:31 PM
snm95ls's Avatar
You will have less overall torque to the wheels.
Check out: http://www.fatboyraceworks.com...are=1
That link should illustrate the difference between the 2 final drive ratios.
Old Dec 10, 2007 | 11:45 PM
that was pretty cool but correct me if im wrong the ys1 trans is a ls trans from a da no a gsr?
Old Dec 10, 2007 | 11:49 PM
snm95ls's Avatar
YS1 simply refers to a specific case design. It is the large shaft cable case used in the 92-93 RS, LS,GS, SE and the 92-93 GSR. The 92-93 GSR had a different gear set with different gear ratios.
Since this case is the large shaft design, it shares internal dimension with the hydro cases. This is why you can swap gear sets between the two cases.
rickles8099
Transmission & Drivetrain
Apr 5, 2009 11:09 PM
civicboy1128
Jun 18, 2008 04:24 AM
cursED
Dec 31, 2002 07:59 PM
Blown90hatcH
Oct 19, 2001 08:58 PM
Blown90hatcH
Oct 18, 2001 09:11 PM
