HAVING WEIRD PROBLEMS WITH MY D16Y7!!
Old Dec 10, 2007 | 02:32 PM
xYoung s15's Avatar
Default HAVING WEIRD PROBLEMS WITH MY D16Y7!!
i got a couple issues..first, my car is only overheating when i am on the highway going 70+, but if i slow down the temp goes back down. i've changed my t-stat,checked my fluid n hoses,and also wired my fan so that its always on. what els could it be?
also..i think i am having fuel problems but im not sure. when im on 1st gear going a little past 15mph the car pulls back n shakes. same thing with 2nd gear if i go past 30.
if anyone knows what the hell is going on with my motor any help is appreciated
thanks
Old Dec 10, 2007 | 03:07 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: HAVING WEIRD PROBLEMS WITH MY D16Y7!! (xYoung s15)
have someone pressure check your cooling system there could be a slow leak ..did you think about the water pump?? and do you have all the air out of the system? with the car shuttering do you have a CEL?
Old Dec 10, 2007 | 03:35 PM
VRD^sam's Avatar
Default Re: HAVING WEIRD PROBLEMS WITH MY D16Y7!! (Throwdown)
what he said,
my buddy had the same problem with his car, he had air in his coolant system.
Old Dec 11, 2007 | 08:40 AM
xYoung s15's Avatar
Default Re: HAVING WEIRD PROBLEMS WITH MY D16Y7!! (VRD^sam)
i highly doubt that its the water pump because i feel the coolant circulating in each hose..im not sure if all the air is out of my system because i just baught it about a month ago. thats probably it, ill go do a pressure test . thanks
and about the shuttering..yes i do. it tells me missfire and that engine is running lean. i've changed sparkplugs,wires,cap rota. any idea?
Old Dec 11, 2007 | 08:47 AM
Archidictus's Avatar
Unceasing Measure
CEL = check engine light.
It sounds like your radiator is on its way out. See if you can find any coolant on or around the radiator - especially the plastic endtanks - next time it starts to overheat. Pull over and pop that hood if you have to.
Old Dec 11, 2007 | 08:49 AM
xYoung s15's Avatar
Default Re: HAVING WEIRD PROBLEMS WITH MY D16Y7!! (Archidictus)
i've checked everywhere for leaks..none
kodylive
May 1, 2013 05:46 AM
tech410
15
Sep 22, 2010 05:22 AM
naptownrex
Oct 18, 2006 03:55 PM
return_2020
Dec 1, 2004 05:57 PM
Evan
Feb 17, 2003 10:56 PM
