un-fraking-real....aluminum dust on top of piston ....
Old Dec 10, 2007 | 01:29 PM
mitsuman's Avatar
Default un-fraking-real....aluminum dust on top of piston ....
Well i went out to shave some of the webbing off my block yesterday to fit my turbo. I was so focused on what i was doing i only pluged the oil dip stick hole but i forgot to cover the spark plug passage way and the exhaust ports. After grinding and grinding, i come to realize that i did not cover the exhaust ports. expletive
Then i realized i didnt cover the spark plug holes, double expletive. So there are TINY TINY particles of aluminum dust on top of my piston, i can only see a tiny bit.
Now from anyones experience will this crap just blow out or will there be damage, im so close to being done, and ive already taken things apart and put back together and so on . i dont know if im going crazy thinking this is OK, or if i should stop being stupid and just take the head off to clean the area. thanks yall\
very frustrating weekend.
Old Dec 10, 2007 | 01:47 PM
Robert Padron's Avatar
Default Re: un-fraking-real....aluminum dust on top of piston .... (mitsuman)
Off course your going to have to take it apart and clean it up in there. Otherwise the metal particles are going to scare the cylinder walls and cause premature wear.
Old Dec 10, 2007 | 02:07 PM
hybrid_KJ's Avatar
Default Re: un-fraking-real....aluminum dust on top of piston .... (Robert Padron)
Aluminum dust shouldn't scar the iron cylinder walls. Hook up a shop vac and try to suck out what you can. If you have access to a pump that can remove fluids pour some atf into the cylinder through the spark plug and then pump the atf out. The aluminum particles should be suspended in the atf and removed when you pump it out. Start the car with fresh oil and run for five minutes and then drain. and put on new filter and oil, you should be good to go. I wouldn't put the turbo on till after you do the oil change.
Old Dec 10, 2007 | 02:49 PM
93supercoupe's Avatar
Default Re: un-fraking-real....aluminum dust on top of piston .... (hybrid_KJ)
yeah, unless there are sizable chunks, i think just blowing it w/ compressed air should do the trick.
Old Dec 10, 2007 | 07:12 PM
AaronJ's Avatar
just start the damn thing
Old Dec 10, 2007 | 07:56 PM
mitsuman's Avatar
anybody else? engine builders?
Old Dec 10, 2007 | 08:22 PM
CoreyR's Avatar
if its just dust from the grinding its fine. what do you think gets into motors that have a turbo with no filter.
Old Dec 10, 2007 | 08:58 PM
Muckman's Avatar
Moderator in Chief
You could always tape a straw to a hose and vacuum it out from the top. I think it'll be fine. Alum is soft, plus its only a fine powder, and there cant be that much that got in. Relax
Old Dec 10, 2007 | 09:07 PM
Tony the Tiger's Avatar
Get a shop vac with a small tube attachment and suck all the bits out... A good dose of compressed air will get pretty much all the **** out of the cylinders. Before you start the engine, squirt some motor oil into each cylinder just in case the aluminum tends to grab onto the rings, etc....
Old Dec 10, 2007 | 09:55 PM
mitsuman's Avatar
Default Re: un-fraking-real....aluminum dust on top of piston .... (Tony the Tiger)
thanks all for the advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote"> Before you start the engine, squirt some motor oil into each cylinder just in case the aluminum tends to grab onto the rings, etc....</TD></TR></TABLE>
what will this do exactly, this is so the bits stick to the oil on the way out? i the top of the piston has some wd40 on it, i sprayed the block when it was sitting in my garage. another problem i dont have a header, will it be a problem going through my turbine? this is after cleaning it out of course. thanks
Old Dec 11, 2007 | 02:51 PM
mitsuman's Avatar
Old Dec 11, 2007 | 06:18 PM
HiProfile's Avatar
You just run the manifold w/o the turbo (or no mani at all). There's no law that states you need a turbo on a turbo manifold. It just isn't great for power
brucepick
Jan 22, 2011 08:51 PM
luckypon7
Jul 12, 2005 01:33 PM
mntdewred
Jun 3, 2005 02:23 PM
mongoliandonuts
Jul 7, 2004 09:10 AM
pr0jektdc2
Nov 22, 2002 05:11 AM
