I hear a high pitched squeeking in my engine. What's wrong?
Old Dec 10, 2007 | 12:52 PM
Blackdogz's Avatar
Default I hear a high pitched squeeking in my engine. What's wrong?
i have a 99 honda civic ex and when i drive it sometimes i hear a squeeking noise coming from the right hand side over by the battery. I thought it was a loose belt but i checked the belts but they are on the other side of the engine. I'm confused on what it is and if it's something to worry about. What should i do?
Old Dec 10, 2007 | 02:13 PM
archuletac's Avatar
Default Re: I hear a high pitched squeeking in my engine. What's wrong? (Blackdogz)
does it seem to dissappear when you push in the clutch? sounds like a throw out bearing to me.
Old Dec 10, 2007 | 02:20 PM
i.'s Avatar
i.
might be the pcv valve.
to check, when the motor is making the noise, loosen the oil cap to relieve the pressure in the crank case. if the noise stops, the pcv valve is prolly bad.
Old Dec 10, 2007 | 02:37 PM
Lscivic1999's Avatar
Default Re: (i.)
maybe taking the car to a expirience mechanic would help...
lvlrkmart
Sep 2, 2009 04:02 PM
v8killaz
May 13, 2009 09:41 PM
93_hatchie
Feb 23, 2009 01:37 PM
Sic_DA_Nine
Aug 14, 2006 09:13 AM
Defcon2030
Jul 17, 2006 04:01 PM
