I hear a high pitched squeeking in my engine. What's wrong?
i have a 99 honda civic ex and when i drive it sometimes i hear a squeeking noise coming from the right hand side over by the battery. I thought it was a loose belt but i checked the belts but they are on the other side of the engine. I'm confused on what it is and if it's something to worry about. What should i do?
might be the pcv valve.
to check, when the motor is making the noise, loosen the oil cap to relieve the pressure in the crank case. if the noise stops, the pcv valve is prolly bad.
