NEED help with leaks..in cylinder head
Old Dec 10, 2007 | 12:20 PM
charlie_sohc's Avatar
Default NEED help with leaks..in cylinder head
make long story short.....got head from local ported shop, put on head burns oil like hell, took off oil in every piston and #2 is the worse...though is the guides sent it back to the shop...its check out good...I have it check a second time at a different shop guides check out good...I have oem valve seal on...we check the block, head gasket...all good?? what could be the problem(s)??? the only thing that we see wrong is that looks like they scar the valve itself??
Old Dec 10, 2007 | 03:42 PM
slomofo's Avatar
GDD Member
Is your head gasket upside down?
Old Dec 10, 2007 | 09:15 PM
Default Re: (slomofo)
no we check, it can only go one way
Old Dec 10, 2007 | 11:58 PM
wed3k's Avatar
whats the condition of your rings? did it blow the head gasket?
Old Dec 12, 2007 | 01:55 AM
methos713's Avatar
Default Re: NEED help with leaks..in cylinder head (charlie_sohc)
I'm having the same problem with mine, but instead its leaking coolent from the head/block. Hopefully the resuface I got will work. But yeah....
Did you replace the valve seals w/ new ones? And if the valves is scar'd, might as well get new ones. Yeah, also look into your rings and do a leak test.
Old Dec 14, 2007 | 12:37 PM
Default Re: NEED help with leaks..in cylinder head (methos713)
nope car runs good with the stock head just this head it burns oils and leaks
thewrai6th
Oct 12, 2009 03:45 PM
g0tgot
Jul 3, 2009 07:14 PM
mf1990
Jun 17, 2009 09:11 PM
shifts
Apr 6, 2007 02:33 PM
Br1t1shguy
Dec 16, 2006 07:27 PM
