CAR WOES!!!!!?????
Old Dec 10, 2007 | 11:33 AM
white99CF's Avatar
Default CAR WOES!!!!!?????
somebody please help ive gota 99 accord dx i/e plugs, wires, walbro 255lph f/p.
symtoms: car starts up fine soon as i start to accel it loses power the harder i accel. once i shift to 2nd still power loss then once i kick the clutch n to stop the car dies could n e one please hlp me out.
ie jus spent like 400 on the car so far tryina get it right
brand new:f/p, fpr,tps, map sensor.
Old Dec 10, 2007 | 11:37 AM
pimpuall's Avatar
Default Re: CAR WOES!!!!!????? (white99CF)
Did you get it tuned after you installed a larger fuel pump?
Old Dec 10, 2007 | 11:40 AM
kchungb17a's Avatar
Default Re: CAR WOES!!!!!????? (pimpuall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpuall &raquo;</TD></TR><TR><TD CLASS="quote">Did you get it tuned after you installed a larger fuel pump?</TD></TR></TABLE>
Yes, why did you get a larger fuel pump? That is over kill for your application. The stock fuel pump is more than sufficient for a stock setup, which is pretty much what you have. Dollars to donuts, that's your problem.
white99CF's Avatar
didnt consider that not knowing. ****!
Old Dec 10, 2007 | 11:42 AM
kchungb17a's Avatar
You won't be able to tune unless you have a tunable ECU. I'd just put the stock fuel pump back in.
Old Dec 10, 2007 | 11:43 AM
white99CF's Avatar
Default Re: CAR WOES!!!!!????? (kchungb17a)
well i thought that my stock one was goin bad that wus the whole point of change
Old Dec 10, 2007 | 11:57 AM
kchungb17a's Avatar
What made you think it was going bad? And if you changed it, it should've been with the same one. A 255lpg pump will deliver too much fuel to the engine, causing it to run rich, causing it to lose power. That is a pump that is recommended to run forced induction on 4 cylinder engines which require more fuel than the stock pump can deliver.
Old Dec 10, 2007 | 12:28 PM
white99CF's Avatar
honestly i doubt thas my problem tho its too inconsistant and its killin me it seems to make like a electrical pinging noise once it loses power.I can be on the freeway at times when it could be fine then if i let my foot off the gas then press again the power is gone. I JUST DONT GET IT!
The car is about to see boost as soon as its starts back runnin right.
small turbo not lookin for stupid numbers
Old Dec 10, 2007 | 12:57 PM
kchungb17a's Avatar
intermittent electrical problems are the WORST. It's really difficult to say what the problem is. But if you're going turbo then hang on to the 255lpg pump but definitely switch back to a stock spec pump until then.
Old Dec 10, 2007 | 01:01 PM
white99CF's Avatar
ok thanks for the input man its really givin me a killer time the car wont even make it around the corner sometimes. Well hopefully somethin will come up
Old Dec 10, 2007 | 02:25 PM
white99CF's Avatar
any more input would be gladly appreciated!!!!!!
could it be my IACV needs to be cleaned
Old Dec 11, 2007 | 10:30 AM
EuroKing99's Avatar
try changing out ur main relay. they have been known to hsve weak soldering points. i had a similar problem that went away with a new relay. cleaning ur iacv isnt a bad idea and couldnt hurt, just make sure u remove the o-ring before u spray it with the cleaner. i used brake clean on my iacv two days ago and it shined like brand new. oh, and make sure ur air filter is clean as well. dirty filter = bad idle
NovaRex
Dec 4, 2015 05:10 PM
classdork987654
Jan 1, 2009 01:16 AM
VRD^sam
Aug 15, 2007 12:53 PM
SuperSteve737
May 29, 2006 01:39 PM
wisjdmhonda
10
Apr 22, 2004 07:41 PM
