corner lights for jdm itr front end!!
Old Dec 10, 2007 | 08:19 AM
imsickofrice's Avatar
Default corner lights for JDM ITR FRONT END~!
okay guys, so heres my problem. I tried searching already but cant find anything about this. my problem is i got a 2000 gsr with a jdm front end, and i cant get my sidemarkers, rear tail, and front headlight turn signal, all to work at the same time. when i wire it up to the front turn signals it blinks at different times. do i need a relay for the headlight turn signals to stay on AND blink? i cut all my wires up so if you guys have the wire colors and which one to hook up to which wire, that'd be great.
Modified by imsickofrice at 8:37 PM 12/10/2007
Old Dec 10, 2007 | 09:50 AM
Default Re: corner lights for jdm itr front end!! (imsickofrice)
x1
Old Dec 10, 2007 | 04:53 PM
x2
nobody knows how to do this!? people WITH ITR FRONT ENDS PLEASE HELP
Old Dec 10, 2007 | 04:58 PM
Padawan's Avatar
Darth ModerVader
I'm not sure what you're having difficulty with. You should not need to touch the tail light wiring at all.
Your existing corner lights should have 3 wires: a ground, a parking light positive and a turn signal positive.
If you're using the stock bulb holders, then you don't need to change any of the wiring. If you're using the JDM bulb holders, the corner lights do not light up with the parking lamps, they only function as turn signals. Therefore, you would connect one wire to your existing ground, and the other to the positive lead for the turn signal. You do the same for your side markers, and your city lights connect to the parking light wires.
Old Dec 10, 2007 | 07:36 PM
Default Re: corner lights for jdm itr front end!! (Padawan)
i believe theres a way for it to stay on parking light mode AND blink. but i could be wrong.
Old Dec 11, 2007 | 05:06 AM
Padawan's Avatar
Darth ModerVader
What bulb sockets are you using?
Old Dec 11, 2007 | 05:47 AM
LSTEG98's Avatar
https://honda-tech.com/zerothread?id=1346217
Old Dec 11, 2007 | 07:52 AM
the one that comes with the stock jdm itr headlight(non hid).
Old Dec 11, 2007 | 07:57 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imsickofrice &raquo;</TD></TR><TR><TD CLASS="quote">the one that comes with the stock jdm itr headlight(non hid).</TD></TR></TABLE>
Then they will only function as turn signals, not as parking lamps. The city lights are used in place of parking lamps on the JDM headlights.
Old Dec 11, 2007 | 10:03 AM
mr_gs-r's Avatar
can anyone verify if the side markers on a jdm front are supposed to blink or not?
Old Dec 11, 2007 | 10:07 AM
Padawan's Avatar
Darth ModerVader
Default Re: corner lights for jdm itr front end!! (mr_gs-r)
Side markers as in the corner lamps of the headlights, or as in the small lamps in the fenders?
Old Dec 11, 2007 | 10:20 AM
im guessing he wants to know if the stanley side (fender) markers are supposed to blink.. and YES they are supposed to BLINK only. and not stay on
Old Dec 11, 2007 | 10:55 AM
mr_gs-r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Side markers as in the corner lamps of the headlights, or as in the small lamps in the fenders? </TD></TR></TABLE>
No not the corner lights in the headlight housings, the stanley sidemarkers on the fender; Are they supposed to blink or stay on constantly?
Old Dec 11, 2007 | 11:16 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_gs-r &raquo;</TD></TR><TR><TD CLASS="quote">No not the corner lights in the headlight housings, the stanley sidemarkers on the fender; Are they supposed to blink or stay on constantly?</TD></TR></TABLE>
Blink only.
Old Dec 11, 2007 | 11:30 AM
so theres no way i can use like relays and make the headlight corners stay ON and then blink (cut off parking light signal while blinking) then when the turn signal turns off, make the bulbs stay on again?
Old Feb 11, 2008 | 04:15 PM
DC2FRMDABAY's Avatar
* B A N N E D *
Blink only. </TD></TR></TABLE> It cant be.. ive seen people have ther side marker on then when they signal it blinks so ther is a way!
Old Feb 11, 2008 | 05:49 PM
Padawan's Avatar
Darth ModerVader
Default Re: corner lights for jdm itr front end!! (DC2FRMDABAY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2FRMDABAY &raquo;</TD></TR><TR><TD CLASS="quote"> It cant be.. ive seen people have ther side marker on then when they signal it blinks so ther is a way! </TD></TR></TABLE>
You can wire the side markers to blink and stay on, though they will blink alternately with the rest of the turn signals and this is not the way the OEM lights are wired.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imsickofrice &raquo;</TD></TR><TR><TD CLASS="quote">so theres no way i can use like relays and make the headlight corners stay ON and then blink (cut off parking light signal while blinking) then when the turn signal turns off, make the bulbs stay on again?</TD></TR></TABLE>
You can use the USDM dual-filament bulb holders to accomplish this, though if you wire of the city lights, the corner "parking lights" would be redundant.
MightyHyman
12
Oct 2, 2012 05:31 PM
fryman
12
Nov 7, 2011 09:42 AM
SpoolnByYou
Nov 28, 2006 01:49 PM
jonyb
May 24, 2004 08:28 AM
SKRacer
Dec 25, 2001 02:14 PM
