skunk2 manifold extrude honed?
Old Dec 10, 2007 | 01:56 AM
Dr.Honda's Avatar
Default skunk2 manifold extrude honed?
im able too get a used skunk2 manifold. its pretty old and has a **** load of miles on it. i was wondering if extrude honing it would be sufficent. OR does it come flowing well enough. i want too clean it up a bit before i install it, IF i get it. does someone see what im getting at?
Old Dec 10, 2007 | 07:34 AM
all-mtr-teg's Avatar
Default Re: skunk2 manifold extrude honed? (Dr.Honda)
Even though its used, once you clean it up and if you do extrude hone it, it will be good as new. Just make sure if you get a larger bore TB that you bore the IM to the TB size, and maybe even a little larger.
Old Dec 10, 2007 | 09:40 AM
Dr.Honda's Avatar
extrude honing is expensive, and if i dont need it, i dont want too spend the cash. BUT it does make a noticable difference. ill get a biger t/b too.
i know someone will say the skunk2 manifold is a waste, but on the h22, it does make power iver the euro r manifold. ive seen dyno graphs that proved it.
2kdrift
Jan 2, 2016 08:06 PM
gixxerboy750
23
Aug 12, 2010 11:32 AM
sway892
Aug 10, 2005 02:46 PM
RayB
10
Jan 23, 2004 10:26 AM
