Confused between CP 84mm and Wisco 81mm (Different Compression)
Old Dec 10, 2007 | 12:40 AM
aladdin's Avatar
Default Confused between CP 84mm and Wisco 81mm (Different Compression)
Okay, I started this LST project long time ago and was buying whatever parts I found to be at good price.
I have a darton sleeved LS short block with stock bore 81mm. I already have 2 sets of pistons, I have wiscos in 81mm 9.2 compression and CP in 84mm in 9.7 compression. Should I bore to 84mm and sell the wiscos? If so, would the 9.7 compression be safe for 500whp goal?
BTW, I bought both sets a year ago because they were at a good deal which I could not miss.
Old Dec 10, 2007 | 04:13 AM
b16a4's Avatar
Default Re: Confused between CP 84mm and Wisco 81mm (aladdin)
wiseco
Old Dec 10, 2007 | 11:33 AM
champLSinteg's Avatar
Default Re: Confused between CP 84mm and Wisco 81mm (b16a4)
i like a little higher compression but if you can use the wiseco's at 81mm i'd do that. No need in going bigger if you dont really need to...just boost up!
Old Dec 10, 2007 | 09:09 PM
aladdin's Avatar
Okay, so I'll use the wiseco's and further when I need to bore I have the CP.
Old Dec 10, 2007 | 11:02 PM
aladdin's Avatar
Default Re: (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">Yea, or sell the CP's and have money to buy 81.5 wisecos down the road lol
Then you can sell the block one day and someone can still have fun with it.</TD></TR></TABLE>
Yeah, I will sell the block once I have the bore to 86mm
Old Dec 11, 2007 | 06:13 AM
agrn93ls's Avatar
Default Re: (aladdin)
i dont know a whole lot about sleeve thickness and what not but the amount of material left and if you are getting close to the edge of loosing strength in the sleeve i would be considering that. i would also talk to the person that will be tuning the set up to get their opinion.
the CP's you bought... i would research and see if they are the "newer" CP's that were built after the valve relief issue's. I personally like the Wiseco's though and used those for mine.
Old Dec 11, 2007 | 09:06 AM
b20vtech's Avatar
u can reach ur goal of 500whp with a 81mm bore, just depends on what ur turbo is capable of making. imo
Old Dec 11, 2007 | 12:17 PM
aladdin's Avatar
I see most of the people here are diggin the Wiseco's.
JarrettL
Honda S2000
Jun 14, 2012 03:09 PM
yrpin5th
51
Dec 29, 2008 05:36 PM
pipe718
Jun 13, 2008 09:54 AM
89a6T
Apr 19, 2006 12:56 PM
YOSOLO CRX
13
Nov 13, 2003 08:53 PM
