Confused between CP 84mm and Wisco 81mm (Different Compression)
Okay, I started this LST project long time ago and was buying whatever parts I found to be at good price.
I have a darton sleeved LS short block with stock bore 81mm. I already have 2 sets of pistons, I have wiscos in 81mm 9.2 compression and CP in 84mm in 9.7 compression. Should I bore to 84mm and sell the wiscos? If so, would the 9.7 compression be safe for 500whp goal?
BTW, I bought both sets a year ago because they were at a good deal which I could not miss.
Re: Confused between CP 84mm and Wisco 81mm (b16a4)
i like a little higher compression but if you can use the wiseco's at 81mm i'd do that. No need in going bigger if you dont really need to...just boost up!
Re: (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 »</TD></TR><TR><TD CLASS="quote">Yea, or sell the CP's and have money to buy 81.5 wisecos down the road lol
Then you can sell the block one day and someone can still have fun with it.</TD></TR></TABLE>
Yeah, I will sell the block once I have the bore to 86mm
Re: (aladdin)
i dont know a whole lot about sleeve thickness and what not but the amount of material left and if you are getting close to the edge of loosing strength in the sleeve i would be considering that. i would also talk to the person that will be tuning the set up to get their opinion.
the CP's you bought... i would research and see if they are the "newer" CP's that were built after the valve relief issue's. I personally like the Wiseco's though and used those for mine.
YOSOLO CRX
13
11-13-2003 08:53 PM
