Would GSR cams be better for a b16 w/ boost?
that's a really hard question it depends how much boost what are you tryin to do with the car......a lot of people run both those cams and are very happy with them. i've also seen both of them make over 600hp. one thing to take in to consideration is what you will be reving to. the ctr's will make power up till i believe like 9000 and gsr's are around 8000(i may be wrong but you get what i'm sayin) also like a turbo cam. it has high lift short dur. but a lot of people say a mild all motor cam will work better for boost. i'd run what you got and switch them out if your not happy.
http://www.crower.com/cat/impo...shtml
some spec to give you an idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt »</TD></TR><TR><TD CLASS="quote">one word will answer that queston.. YES</TD></TR></TABLE>
Stock B series Vtec cams are as follows:
ITR/CTR > GSR > B16
People regularly see gains of 15+whp on a ~300whp turbo car when they switch from GSR to ITR/CTR cams. They are definitely worth the money to upgrade.
ITR/CTR > GSR > B16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg »</TD></TR><TR><TD CLASS="quote">bigger is better</TD></TR></TABLE>
lol...to a point. I wouldnt go swapping in some MazWorks cams into a stock block ~300whp car, but as far as OEM goes, you have a point
Maybe this might help you a little. A little proof or comparison between regular b16 cams and gsr cams.
http://www.evans-tuning.com/comp3.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigZeke5 »</TD></TR><TR><TD CLASS="quote">Maybe this might help you a little. A little proof or comparison between regular b16 cams and gsr cams.
Good find...i didnt realize the difference was that noticeable though
Your probably right, I don't know, however I do know it will probably be easier and faster to find gsr cams then ctr/itr oh and alot cheaper. What I liked about the gs-r cams was that you got more power with less boost. Yeah, 1 psi is not a lot of difference, but one psi less is less work on the engine and you get noticable gains of up to 30 hp pending on your tuner. That works for me man. That's what i'm gonna use. Right now I'm just saving money so I can buy a real air/fuel meter, and to get my car tuned on a dyno.
