coolant problem - need help
Old Dec 8, 2007 | 07:51 PM
foom1986's Avatar
Default coolant problem - need help
alright guys,
this morning i was driving for about 15 minutes and notice light steam coming out of my front grill. i popped the hood...and coolant was splattered everywhere. the coolant reservoir cap came loose. the radiator wasn't leaking either. what could possibly be the cause of this?
thanks
Old Dec 8, 2007 | 08:17 PM
ShaggyZ6's Avatar
the coolant overflowed onto the hot radiator which caused it to steam. either someone left the cap loose or the cap is faulty and wont stay tight.
Old Dec 8, 2007 | 09:12 PM
mugenkilla899's Avatar
Default Re: coolant problem - need help (foom1986)
this happened to my 93 civic ex sedan, it started out at light steam and splatted coolant....i bet its your thermostat....
Old Dec 9, 2007 | 12:01 AM
philosofy1's Avatar
Default Re: coolant problem - need help (mugenkilla899)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenkilla899 &raquo;</TD></TR><TR><TD CLASS="quote">this happened to my 93 civic ex sedan, it started out at light steam and splatted coolant....i bet its your thermostat....</TD></TR></TABLE>
i was thinking thermo too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foom1986 &raquo;</TD></TR><TR><TD CLASS="quote">alright guys,
thanks</TD></TR></TABLE>
OP, doesn't hurt to replace your thermo, it's cheap and easy to do.
Old Dec 9, 2007 | 04:41 AM
instrument's Avatar
you people are nuts
maybe you didn't tighten the cap enough and it worked its way loose.
tighten it and make sure there's an actual problem.
Old Dec 9, 2007 | 05:14 AM
m735is's Avatar
If the <U>resovoir </U>cap (over flow bottle) popped off because of pressure, you could have a bad radiator cap, thermostat or head gasket leak. I would start with a new radiator cap.
Where was the temp gauge needle when this happened?
aziaticvang
28
Jan 17, 2008 02:26 PM
bokals
Mar 8, 2007 07:04 PM
TOO MUCH TORQUE
Feb 4, 2007 07:50 PM
IntegraTionR
Sep 18, 2005 08:22 PM
Boosted Chemist
Aug 21, 2004 08:45 PM
