How To: 1999-2000 Power window conversion w/ functioning rear wiper
Old Dec 8, 2007 | 07:09 PM
Dr. Willy's Avatar
Default How To: 1999-2000 Power window conversion w/ functioning rear wiper
First of all a <U>BIG</U> thanks goes out to 714DC4 for helping me out with this and emailing me the pages out of the helms manual, decided i would post up the pages out of the honda book cause i searched and didnt find any help on this.
This is where the 3 wires go in the rear plug of the floor harness in the car
This is where the solid green wire goes into the fuse box plug
And this is where the remaining two wires go in the front main plug of the floor harness
Once again big thanks to 714DC4 for helping out with this one, you want to add this to the faq page.
Old Dec 10, 2007 | 02:39 PM
714DC4's Avatar
Default Re: How To: 1999-2000 Power window conversion w/ functioning rear wiper (Dr. *****)
Thanks for the props, this is some very useful information that definitely needs to be added to the faq's or saved.
Old Jan 6, 2008 | 06:40 PM
pikaabooh's Avatar
guys i am in the middle of converting my 99 DX to power window and i think this will be helpful can some one help me to digest this items and send me the details also. Also i encounter a problem using the 96-98 harness hope you can help me.
1. the 96-98 floorharness coupe for the rear side have 2 plug while the 99 existing only have one big one( do i just need to re-use the one i taken off and re-wire it?)
3.the 96-98 floorharness coupe for the driver side side have 6 plugs
towards the fuse box :
1 big green plug (going to fuse)
1 small green plug (where is this going or is this required)
1 blue plug (going to fusebox)
1 white plug (where is this going or is this required)
1 gray plug( also do not match do i need to cut the one from existing)
I onlyremember removing only 1 Big green plug and 1 blue plug were will the other plug go?
please help!!!!!!!
Old Jan 6, 2008 | 08:54 PM
Dr. Willy's Avatar
Default Re: How To: 1999-2000 Power window conversion w/ functioning rear wiper (pikaabooh)
the best advice i can give you is to pick up a 99-00 harness. The 96-98 is very differnt and you would have to add/change a lot of wire to make it work.
Old Jan 6, 2008 | 09:15 PM
angel_i's Avatar
If you can, try to stick w/ either the 96-98 or 99-00 models. I Think that is definately the fastest way to convert over.
Old Jan 9, 2008 | 03:11 PM
pikaabooh's Avatar
gee... that aint good.. do you know where i can buy those
Old Jan 10, 2008 | 03:13 PM
pikaabooh's Avatar
gus can you give me a snap/shot pictures of the fuse box with everything connected i forgot where the foglight cables are and the yellow connector. also help i dont have any wiper and signal light on my car when i try to test
Old Jan 10, 2008 | 04:23 PM
ek dude's Avatar
Old Jan 11, 2008 | 05:17 PM
pikaabooh's Avatar
Default Re: How To: 1999-2000 Power window conversion w/ functioning rear wiper (ek dude)
guys need help bad .. my car wont start it is cranking but it is not going thru... also no wipers and signal lights
Old Jan 12, 2008 | 11:22 PM
pikaabooh's Avatar
now my car have malfunction indicator lamp on after returning everything anyone help
Robby Keeney
Feb 11, 2016 11:31 PM
JTmoney
Oct 4, 2007 09:27 AM
TH22EK9
Sep 9, 2006 01:27 PM
egg_baLLa
Jun 1, 2006 02:52 PM
scottybh
Mar 12, 2006 07:29 PM
