EG To Ek Swapping Questions?
Old Dec 8, 2007 | 09:23 AM
XzzRzzX's Avatar
Default EG To Ek Swapping Questions?
I have a Eg Hatch with a sec gen b16, i just bought a 99 civic 4 door. I want to transfer the engine over, i know i have to use a 99-00 rear bracket, i was thinking of buying hasport mounts to use, cause the billit mounts in the eg won't work right? Also will the linkage from the b16 tranfer over also, Will the power steering bracket fit the b16? If there is anything else i need to worry about please let me know..
Thanks
Old Dec 8, 2007 | 10:37 AM
chad's Avatar
Moderator
Default Re: EG To Ek Swapping Questions? (XzzRzzX)
if you don't have emmissions then all you need to do is get an obd2 to obd1 conversion harness and run your ecu. you'll need to change some of the plugs on your engine ie, dizzy plugs, injector plugs (or you can just swap obd2 injectors to your b16)
you can use your rear hasport mount in your eg in the ek but will need to get the drivers side upper and tranny upper mount since both of those are different between eg and ek....
shift linkages are the same...
you'll need to use your LX engine wire harness on you b16 this will require lengthening some of the plugs ie, vtec pressure and sylinoid (sp)
off the top of my head that is all
nastysci93
Aug 7, 2011 08:58 AM
scbmx87
12
Sep 1, 2008 08:35 AM
dturbo
Mar 5, 2007 01:57 PM
Corbic
Jul 26, 2005 10:38 PM
90civichb
Apr 21, 2005 05:48 PM
