need help finding out this problem....
Old Dec 8, 2007 | 05:40 AM
GSR_hatch936's Avatar
Default need help finding out this problem....
ok i got a vid of the nose maybe that would help alot but when im driving my car make a real ruff sound like the bearings are out but not sure... here's the vid...
http://tinypic.com/player.php?v=73melvr&s=1
Modified by GSR_hatch936 at 1:15 PM 12/8/2007
Old Dec 8, 2007 | 09:50 AM
fastrc2's Avatar
Default Re: need help finding out this problem.... (GSR_hatch936)
ok lets say you do that again on a road that has some gentle curves. as you sway the car to left does the noise get worse or better and the opposit for when you sway to the right?
Old Dec 8, 2007 | 10:16 AM
i can go straight and the car still makes that noise...
Old Dec 8, 2007 | 10:43 AM
95dxsir2's Avatar
Default Re: (GSR_hatch936)
sounds like a wheel bearing
Old Dec 9, 2007 | 09:52 AM
fastrc2's Avatar
Default Re: (95dxsir2)
yes it will make noise going straight if its a wheel bearing, but if you sway the weight on and off the sides while driving it will identify for sure its a wheel bearing and which one. so once again i ask, does the sound change or go away as you sway the vehicle?
Old Dec 12, 2007 | 03:16 PM
Default Re: (fastrc2)
i think when i sway to the left the sound gets softer... but not sure... it might be the right hand side... not sure will check and reply.
Old Dec 12, 2007 | 03:21 PM
WhiteOnRice's Avatar
When my rear right wheel bearing was bad the noise was constant. Kind of like the brake was always slightly engaged. You could definitely tell which corner it was coming from too.
Old Dec 12, 2007 | 03:24 PM
db8db8db8's Avatar
sounds like a bearing or something with the wheels. Does the car vibrate like crazy while on and off the brake? Also was your CEL always on or after the noise?
Old Dec 13, 2007 | 01:28 PM
Default Re: (db8db8db8)
its not the CEL its the srs and the not seat belt light... lol didnt fell like puttin the seat belt on... but i swayed my car and it make noise on both sides?? maybe their both out by any chance... and the car viberates a little..
Old Dec 13, 2007 | 01:40 PM
mav87's Avatar
its e z to diag. does it goes with engine speed or wheel speed? put in neutral and if it stays with wheel speed check out ur free play
Old Dec 13, 2007 | 03:28 PM
Conway's Avatar
New User
hey i got a problem with my swap eg, its a poorman's type r, the gas is burning but the motor seems to not be pulling like it use to, do anyone of yah know why,
XLI
Sep 7, 2016 10:19 AM
EM1ED
10
May 25, 2011 08:18 AM
kpop
Aug 16, 2006 05:43 AM
maivietla
Apr 19, 2005 10:44 AM
