non v tec vs v tec
Old Dec 8, 2007 | 04:17 AM
Blazen_angles's Avatar
Default non v tec vs v tec
i bave a b 18 b without a v tec would it be better to get a v tec head for it or not
Old Dec 8, 2007 | 07:55 AM
crxfreak1117's Avatar
Default Re: non v tec vs v tec (Blazen_angles)
u will get more power but there is more work that just slappin the vtec head on and i would suggest using the b16 head it flows better than the b18 vtec head
Old Dec 8, 2007 | 08:06 AM
lrcrx90's Avatar
crxfreak is right you will get more power but it requires alot of work one the b16 head is better and requires modification to bolt on also since the b16 head loves to rev you may want to secure the block since its not made to rev as hard and you don't run into problems in the long run. also with that engine i would consider going turbo
Old Dec 8, 2007 | 08:34 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: non v tec vs v tec (crxfreak1117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxfreak1117 &raquo;</TD></TR><TR><TD CLASS="quote">u will get more power but there is more work that just slappin the vtec head on and i would suggest using the b16 head it flows better than the b18 vtec head</TD></TR></TABLE> No it doesn't and that has been proven.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lrcrx90 &raquo;</TD></TR><TR><TD CLASS="quote">crxfreak is right you will get more power but it requires alot of work one the b16 head is better and requires modification to bolt on also since the b16 head loves to rev you may want to secure the block since its not made to rev as hard and you don't run into problems in the long run. also with that engine i would consider going turbo </TD></TR></TABLE> Last time I checked the b18c5 head is the same casting and revs higher then a b16... and the gsr head revs just as high....
One thing I will agree on is do work to keep the motor lasting, a set of ARP rod bolts are a must.
lsvtec is covered here quite often search.
Old Dec 8, 2007 | 09:06 AM
turboZChatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazen_angles &raquo;</TD></TR><TR><TD CLASS="quote">i bave a b 18 b without a v tec would it be better to get a v tec head for it or not</TD></TR></TABLE>
If your asking a question like this you should do a little more research
https://honda-tech.com/zerosearch not being a d*** just saying you should research what your getting into before doing it
Old Dec 8, 2007 | 10:35 AM
ludesrv's Avatar
Umm what?
Both B16 2nd gen heads and ITR heads are identical in cast. ITR head has a mild port and polish out of factory. GSR heads simply have different bolt patterns for the intake manifold but other then that it's all interchangeable.
First gen B16 heads have single valve springs and aren't as rev friendly out of the box, but both B16 and B18 heads rev pretty much the same.
The best revving head, stock, is the B16B, but it's cost is simply not worth it.
For an lsvtec, you MUST do rod bolt if you plan on revving higher then 8000rpm. I've seen lsvtec blow up after a few weeks of 8500rpm. The bottom end is not designed to rev, so special concideration must be taken. It will also be a low compression engine, don't expect to lay down more then 160whp.
Old Dec 8, 2007 | 10:39 AM
Ass$nyper's Avatar
Default Re: non v tec vs v tec (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
Umm what?
.</TD></TR></TABLE> No, they are not the same it's not just the manifold.
Google pics or look here, it's more then just a few bolts.
While parts do interchange there are things in the head it self like it's shaping that differ them.
Old Dec 8, 2007 | 12:30 PM
Default Re: non v tec vs v tec (***$nyper)
i was talkin about the jdm b16 head compared to the usdm gsr head sorry if i was wrong
Old Dec 8, 2007 | 12:45 PM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote"> No, they are not the same it's not just the manifold.
Is that a fact? I'd like to see what other differences. There aren't any noticeable difference that would make the GSR head a bad head to use in an LSVTEC tho.
Old Dec 9, 2007 | 12:35 AM
StorminMatt's Avatar
Ah, the neverending battle between the P72 and PR3 head casting. Who knows which really IS better. Given that there is no definitive answer yet after all these years, I am inclined to think it is a draw. Regardless, either should work fine on an LS-VTEC, and the B18C1 head will give you a better compression ratio if you decide to use the stock pistons.
Old Dec 9, 2007 | 04:07 AM
thevtecnician's Avatar
Default Re: non v tec vs v tec (StorminMatt)
I want to see some flow charts between the pr3 head and p72 heads. That's really the only way to know for sure, anything else is speculation really. But it is a fact that the p72 head raises compression in setups like this. I know someone has a link or something where a comparison like this has been done
Old Dec 9, 2007 | 09:21 AM
gibsanez's Avatar
Default Re: non v tec vs v tec (thevtecnician)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevtecnician &raquo;</TD></TR><TR><TD CLASS="quote">I want to see some flow charts between the pr3 head and p72 heads. That's really the only way to know for sure, anything else is speculation really. But it is a fact that the p72 head raises compression in setups like this. I know someone has a link or something where a comparison like this has been done</TD></TR></TABLE>
https://honda-tech.com/zero...age=1
96ej8MR
Jun 27, 2007 06:28 PM
Jankis
Nov 20, 2006 10:55 AM
latinf86
Aug 12, 2006 09:47 PM
B-JUSTINE
May 26, 2006 02:38 PM
drudy
Feb 12, 2005 06:10 PM
