what lsd is this?
Old Dec 8, 2007 | 04:06 AM
anton_'s Avatar
Default what lsd is this?
i have a lsd that i thought would fit my crx vtec, but it didnt.
i think i have a 4,2 final drive
the lsd has 64 tooth, i want to sell it but i need to know whar gearbox it will fit
here is some pictures
[IMG][/IMG]
the bearing is 3,15"
[IMG][/IMG]
it is 7,48" wide
[IMG][/IMG]
it is 5,51" high
Old Dec 12, 2007 | 10:50 PM
anton_'s Avatar
Default Re: what lsd is this? (anton_)
someone
Old Dec 13, 2007 | 05:50 AM
pgpbubble's Avatar
Looks like an OEM b16 cable LSD
Old Dec 13, 2007 | 07:28 AM
thehatchninja's Avatar
that's a 14 bolt LSD it came in the B16/GSR JDM LSD transmissions. Hope that FD never breaks.
Old Dec 13, 2007 | 07:01 PM
soulpwr's Avatar
Default Re: (thehatchninja)
The diff will probably blow before the gear breaks. I pulled one of those out of my YS1
Old Dec 14, 2007 | 07:53 AM
I remember a guy on here trying to buy one of those ring gears forever.
Old Dec 15, 2007 | 05:18 PM
Honda Bull's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">that's a 14 bolt LSD it came in the B16/GSR JDM LSD transmissions. Hope that FD never breaks. </TD></TR></TABLE>
Bingo. The bolts are much nearer the FD teeth than the newer diffs, too. That's another hint.
Old Dec 16, 2007 | 01:37 AM
anton_'s Avatar
Default Re: (Honda Bull)
so its for the ys1? does it not fit another gearbox?
Old Dec 16, 2007 | 07:14 AM
Honda Bull's Avatar
Default Re: (anton_)
It's definitely from the cable JDM B16 transmission. I think that's YS1. I'm not the most familiar with the older designations. Not too sure if it will fit in others actually. Not without any work to the transmission casings, I would think.
Not sure if you pulled that diff out or just bought it like that, but if you can get access to the transmission case that was removed from (photos or actually see it in person), you'll see that the casing's oil channels/fins surrounding the differential has been grinded down a lot by Honda to make that LSD fit in there. The actual housing of that OEM LSD is just shaped much differently than the OEM open-differentials that come in those older transmissions.
Old Dec 16, 2007 | 08:56 AM
anton_'s Avatar
i just bought it like this, so i have nerver seen the case
Old Dec 16, 2007 | 10:49 AM
snowseeker's Avatar
It will fit in other cable cases but fins need to be taken down a bit. I have taken one apart as well, very nifty design inside those diffs.
Old Dec 16, 2007 | 12:42 PM
RPRacing's Avatar
i've got one of these i pulled out of my spare trans. just bought a quaife for it.
its for sale now too and comes witht he ring gear, if you guys know of anything.
Modified by RPRacing at 1:51 AM 12/17/2007
Old Dec 16, 2007 | 09:33 PM
ceri_us's Avatar
&lt;thumpsup&gt;
ekcivic2
Transmission & Drivetrain
Jun 1, 2014 03:29 PM
Wh0 Iz UNREAL07
Nov 11, 2010 09:42 AM
da6xsi06
Oct 6, 2010 04:47 AM
kev tec96
Mar 10, 2004 07:11 AM
wesuri
Oct 30, 2002 11:42 AM
