can you change mileage on a aftermarket cluster?
ok i seared and found a DIY on it but i didnt understand what he was talking about and i had a few questions. first off i want to buy a ex cluster for a 99 civic and i want the mileage to match the one i have now, does anyone have a set by step of this perhaps with pics? also if i do this it is legal im not going to get in trouble or void anything with insurance? thanks for any help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Right here, chief.</TD></TR></TABLE>
He said he searched and found a DIY, but didn't understand it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedoKing »</TD></TR><TR><TD CLASS="quote">ok i seared and found a DIY on it but i didnt understand what he was talking about and i had a few questions. first off i want to buy a ex cluster for a 99 civic and i want the mileage to match the one i have now, does anyone have a set by step of this perhaps with pics? also if i do this it is legal im not going to get in trouble or void anything with insurance? thanks for any help</TD></TR></TABLE>
just take apart the cluster, and mess around til you figure it out, EK gauge clusters are the easiest to roll back, ive done it before, just cant recall the process
ok ill try that i jus wanna make sure that on some odd chance that is happens im not going to get a ticket or in trouble with anyone by replacing the cluster and rolling the miles myself?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Im_a_black_man »</TD></TR><TR><TD CLASS="quote">
just take apart the cluster, and mess around til you figure it out, EK gauge clusters are the easiest to roll back, ive done it before, just cant recall the process</TD></TR></TABLE>
x2
Real easy. Done it numerous times.
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neebs »</TD></TR><TR><TD CLASS="quote">Its illegal - mileage fraud, but if you set it back to the original then yeah its fine.</TD></TR></TABLE>
As long as you set the mileage of the new cluster the same as the old one, it's not fraud. Its required by some states - CA you can only legally replace an odometer if you set the new one to the same mileage, or if that isn't possible set the new one to zero and put a special label in the doorjam showing the difference.
You can remove the speedp from your original cluster and put it the new one
like if you have a cluster with no tach you you can take it out and put it in a cluster with a tach it is all bolt up and works well super easy to do
providing all the faces are the same colour oh ya don't try to remove the needles on the gas and temp gauge they break everytime Trust me I know....
the one im buying has white face plate and i would have to change the mileage from 86,xxx to 120,xxx so i cant swap the speedo out b/c they are different colors.
No it isn't. Next time please check before you spread this info.
https://honda-tech.com/zerothread?id=1882730
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">
No it isn't. Next time please check before you spread this info.</TD></TR></TABLE>
It is illegal in some state, E.g. New Jersey, Kentucky so how is that spreaing misleading info?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neebs »</TD></TR><TR><TD CLASS="quote">It is illegal in some state, E.g. New Jersey, Kentucky so how is that spreaing misleading info?</TD></TR></TABLE>
The OP is not in New Jersey or Kentucky. In fact, so far NO ONE in this thread says they reside in either of those states.
You just plain said it was illegal. You did not source any laws that might be relevant to the OP.
That is how it's misleading.
I would suggest that anyone who plans to modify their vehicle in ANY way should check their local laws before doing so. There are a lot of things that are illegal to do to your car. Find out what you're willing to do before you do it.
Not having a front license plate or changing the mileage on a non-original cluster isn't exactly up to par as say, possession of stolen parts.
Changing your mileage to make it appear that your car has different mileage than it's actual mileage is wrong. Changing the mileage on a replacement cluster just plain isn't the same. Some states might require you to have such work done by a licensed professional.
