D16Y8 Mini Me Swaps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkid15 »</TD></TR><TR><TD CLASS="quote">no you dont.</TD></TR></TABLE>
Have you put a Y8 on a D15B7/B8?
ive heard that when you put a z6 or y8 head on a b7 its still like 4 deg retard and i mean think about it you put the head on and have to run shorter timingbelt.but ive got a z6 on a b7 and it runs good but is a little slugish out of the hole but it still runs a low 15
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inline4wHORE »</TD></TR><TR><TD CLASS="quote">ive heard that when you put a z6 or y8 head on a b7 its still like 4 deg retard and i mean think about it you put the head on and have to run shorter timingbelt.but ive got a z6 on a b7 and it runs good but is a little slugish out of the hole but it still runs a low 15
It won't be sluggish out of the hole.
</TD></TR></TABLE>It won't be sluggish out of the hole.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingrevolution07 »</TD></TR><TR><TD CLASS="quote">no it will work fine with the stock gear. i ran zc/y8 in my old rex no problems
Again, just because it works on a ZC, doesn't mean it will work on everything
Diffrent Deck Heights.
Syndacate, do you have any input on this? I'm just looking for a 100% confirmation before I buy a AEM Tru-Time
Lemme re-phrase my question
"On a D15B7/B8 Block, when using a Y8 head, do you need an Adj. Cam gear"
To my understanding a Z6 head is still 2.5 Degrees off, and a Y8 would be 4.5, so you being a little slugish would be because you are 2.5 degrees off time if my on-going hunch is correct.
Mine is a DOG *Missing/stuttering* out of the hole untill Vtec, and then it takes off.
</TD></TR></TABLE>To my understanding a Z6 head is still 2.5 Degrees off, and a Y8 would be 4.5, so you being a little slugish would be because you are 2.5 degrees off time if my on-going hunch is correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc »</TD></TR><TR><TD CLASS="quote">
"On a D15B7/B8 Block, when using a Y8 head, do you need an Adj. Cam gear"</TD></TR></TABLE>
I'm pretty sure you need one, but I'm not positive, which is why I didn't say anything.
As for the dizzy timing, set it with a timing light, and that should fix your launch problems. It shouldn't be doggin it before 4.5k like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
As for the dizzy timing, set it with a timing light, and that should fix your launch problems. It shouldn't be doggin it before 4.5k like that.</TD></TR></TABLE>
Thanks for the Honesty Syndacate, too many people jump to conclusions *Things like all Vtec solenoids are the same and crap like that* cost other people money* I'm pretty sure its off as everything else is 100% right after alot of time and money ensuring it all was, Lol.
ArchAngel Sabastian
15
Dec 29, 2003 11:04 AM
