90 civic cx with 1.6l wiring issues (post engine swap)
Old Dec 6, 2007 | 07:38 PM
Cone Assassin's Avatar
Default 90 civic cx with 1.6l wiring issues (post engine swap)
Well, let me give you a bit of background about the car. I bought the car with the ZC twin cam which I use to autocross. Then I hydro locked the engine, which caused a nasty hole...or two.
and here's sunshine coming through the engine
So anyway Rebuilding was out and my JDM importer was fresh out of ZC blacktops, so I decided to go back to a d16z6 which brings my Autox class from full C-mod to FSP ( Street Perpared Class) good news for racing bad news for street performance.
This is the d16z6
My problem is that I have 3 codes after the install
14 Eacv
16 Fuel Injection
20 Electric load detector
EACV is my biggest problem, I have 3 different connectors and I don't know which one goes to the EACV. Any Idea which colour wires go to the EACV
as for the other codes any Idea's
Old Dec 6, 2007 | 08:09 PM
Allday07's Avatar
Default Re: 90 civic cx with 1.6l wiring issues (Cone Assassin)
pretty sure its green
Old Dec 6, 2007 | 08:10 PM
Default Re: 90 civic cx with 1.6l wiring issues (Allday07)
I'll look for green
Old Dec 6, 2007 | 10:09 PM
Under Con. CrX's Avatar
you mean D16a6 right cus thats not a Z6
Old Dec 6, 2007 | 11:26 PM
Fezzie's Avatar
Default Re: 90 civic cx with 1.6l wiring issues (Under Con. CrX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under Con. CrX &raquo;</TD></TR><TR><TD CLASS="quote">you mean D16a6 right cus thats not a Z6</TD></TR></TABLE>
lol
Old Dec 7, 2007 | 04:21 AM
My bad.
So if you can figure out the engine, you should know my wiring problem.
Old Dec 7, 2007 | 07:57 AM
jlicrx's Avatar
EACV has 2-wire connector with Black/Yellow and Blue/Yellow wires
IAT (Intake Air Temp) also has 2-wire connector with Red/Yellow and Green/White wires
Fast Idle Control Valve (89-91 Si only) also has 2-wire connector with Black/Yellow and Solid Blue wires
Tandem Control Valve (on DPFI cars only) also has 2-wire connector with Black/Yellow and Solid Orange wires
Old Dec 7, 2007 | 08:36 AM
alscrx's Avatar
Default Re: 90 civic cx with 1.6l wiring issues (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">EACV has 2-wire connector with Black/Yellow and Blue/Yellow wires
Tandem Control Valve (on DPFI cars only) also has 2-wire connector with Black/Yellow and Solid Orange wires</TD></TR></TABLE>
Old Dec 7, 2007 | 08:56 AM
builtsinglecam's Avatar
great project!
Old Dec 7, 2007 | 10:23 AM
well I'm impressed. I'll look into it, Thanks
Old Dec 10, 2007 | 12:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cone Assassin &raquo;</TD></TR><TR><TD CLASS="quote">well I'm impressed. I'll look into it, Thanks</TD></TR></TABLE>
so did you fix it ??
Old Dec 10, 2007 | 04:57 AM
Yeah, I got it running great now, Thanks.
The only thing that I need to figure out is the electric load detector code 20. It hasn't affected anything yet. I've checked my grounds and they're, well, grounded, other than that I'm not sure why I would be getting the code
Old Dec 12, 2007 | 07:48 AM
she's back on the ground and lookin' good runnin' real nice too!
Old Dec 12, 2007 | 09:34 AM
welfarepc's Avatar
lol i was about to say... wheres the vtec? lol
ELD code is when you run an 88-89 ECU in a 90-91. The 90-91's dont have ELD's (in canada anyways) so your ECU throws the code. You can resolve it by getting an under-hood fuse box from an 88-89 and swapping that in the car.
Old Dec 12, 2007 | 09:49 AM
Default Re: (welfarepc)
that's funny because I never had the code before with the ZC twin cam and I was using the same SI ECU
1986civiccrxsi
Classic Hondas
Nov 2, 2007 03:28 AM
basitun
Jun 14, 2007 04:57 AM
pklass
Jun 9, 2006 01:58 PM
gtfourmn
Jun 7, 2003 10:46 PM
