fuel pressure regulator
Old Dec 6, 2007 | 11:12 AM
91redteg's Avatar
Default fuel pressure regulator
what kind of fuel pressure regulators do u recommend. im gonna be running around ten lbs of boost with 440cc injectors, and a walbro 255lph fuel pump. ive heard bad things about the aem fpr's
Old Dec 6, 2007 | 11:17 AM
mighty137's Avatar
What management system??? u might just end up using the stock one......
Old Dec 6, 2007 | 11:18 AM
91redteg's Avatar
Default Re: (mighty137)
i dunno i have a p28 ecu chipped with crome. is that what u mean?
Old Dec 6, 2007 | 11:22 AM
agrn93ls's Avatar
Default Re: (91redteg)
use the stock one
Old Dec 6, 2007 | 11:23 AM
vietjdmboi's Avatar
aeromotive makes a very nice one. it mounts in the stock location of the old one.
mighty137's Avatar
Yup, u should be fine on 10psi on a stock FPR!! Just ask your tuner!! G/L
Your management system will control the flow for the 440's on the stock FPR!!
Old Dec 6, 2007 | 11:28 AM
91redteg's Avatar
k thanx my shop toldf me would need to cuz im using the 255lph fuel pump
Old Dec 6, 2007 | 11:32 AM
JaredKaragen's Avatar
I have seen stock FPR's running more than 400hp.
Old Dec 6, 2007 | 11:35 AM
91redteg's Avatar
Default Re: (JaredKaragen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaredKaragen &raquo;</TD></TR><TR><TD CLASS="quote">I have seen stock FPR's running more than 400hp.</TD></TR></TABLE> sweet im shootin for 250-280 so guess im keepin my stocker
Old Dec 6, 2007 | 11:39 AM
PrecisionH23a's Avatar
Default Re: fuel pressure regulator (91redteg)
As everyone else has said, stock is fine. Whatever you do, don't run the junky B&M as it doesn't always work well with the hp walbro units.
Old Dec 6, 2007 | 11:43 AM
91redteg's Avatar
Default Re: fuel pressure regulator (PrecisionH23a)
thanx alot guys ya'll just saved me like $100
Old Dec 6, 2007 | 12:26 PM
agrn93ls's Avatar
you will probably see a little increase in fuel pressure from the walbro but it shouldn be a problem the tuner should have no problem tuning it like that.
Initial_drift
Feb 2, 2007 03:49 PM
7808
Jan 30, 2006 04:09 PM
oxSLEEPERxo
Dec 27, 2005 07:01 AM
X2BOARD
Apr 10, 2004 03:31 PM
prelittlelude
Jun 13, 2003 08:53 PM
